Noob Trafo question - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 11th October 2015, 02:07 PM   #1
Jaffrie is offline Jaffrie  Indonesia
Default Noob Trafo question
Hi Guys
Need some tutorial. Have a 300Va 240v trafo with 40-0-40 ac out.
What is the actual current output per winding in amps
Old 11th October 2015, 02:15 PM   #2
Mooly's Avatar
Its 300/80 which is 3.75 amps.
So you have two windings each rated at 3.75 amps and 40 volts. That is 150va per winding.
Old 11th October 2015, 02:15 PM   #3
kaputt is offline kaputt  Germany
Theoretical maximum is 3,75A. In practice a transformer doesn't put out current. The load draws current.
Old 11th October 2015, 02:31 PM   #4
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
The AC current rating doesn't translate to the DC current available after rectification and smoothing. After you rectify and smooth you'll generally get just under +/-60VDC unloaded.
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Old 11th October 2015, 02:47 PM   #5
Thks guys for the advice
Aleph 1.2 Trafo question theduker Pass Labs 5 6th October 2013 12:52 AM
Question about trafo maurycy Power Supplies 31 7th March 2012 02:26 PM
Trafo question... Dxvideo Chip Amps 7 26th September 2007 06:33 PM
230v trafo question giantstairs Chip Amps 7 5th March 2007 02:01 PM
uchcstnigc - trafo positioning question Groundloops Chip Amps 1 18th June 2005 03:11 PM
Copyright 1999-2017 diyAudio
