power supply - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 29th September 2015, 01:12 AM   #1
Default power supply
Can someone help to review the power schematic. I built this schematic and every time I turn power on the fuse is blown.
Thanks, For your help
Old 29th September 2015, 02:00 AM   #2
Enzo is offline Enzo  United States
Hey Lugnut, how about either linking us the data sheet for the transformer or at least telling us which model it is.
Calpoly, good internet form would be to start a new thread for your question, since it really does not relate to the problem Lugnut is having and we are discussing here. perhaps there you could explain the idea behind the design. As to troubleshooting, does it blow fuses with the rectifiers removed. How about with the rectifiers installed but the triodes removed.
Old 29th September 2015, 02:11 AM   #3
HollowState's Avatar
The 6AX4s are shorting out the 220V windings. Assuming that's what they are, indirectly heated cathodes. (hard to tell from small pix) With the center tap grounded as well as the anodes, it's as if the the 6AX4 diodes are directly across the 220Vs.
And yes you should start a new thread!
1944: 18 year olds storm the beach of Normandy into almost certain death.
2017: 18 year olds need a safe place because words hurt their feelings.
Old 29th September 2015, 09:48 AM   #4
Ketje is offline Ketje  Belgium
Ketje's Avatar
Mona
Old 29th September 2015, 02:01 PM   #5
coils is offline coils  United States
866a's have a 2.5 volt filament cathode, not 5volt, use half of that transformer if it can provide 10 amps and run the rail right off of the cathode. Also there are caveats regarding burn in after shipment/storage, and preheat beforre plate volts is applied.
Coiler
Old 29th September 2015, 02:03 PM   #6
Also, float the ground on the power transformer center tap, you cant use that with the greatz bridge.
Coiler
Old 29th September 2015, 06:50 PM   #7
Ketje's Avatar
Yes you can.Gives half the voltage at the top.Very usefull for the screen grid of power tubes.More economical (and less heat) then series resistances and evt. stabilisation or big chemicals to get low impedance drive and lower voltage.
Mona
Old 30th September 2015, 09:13 PM   #8
Default Power Supply
Thank you for your all input. I update schematic to disconnect ground from high voltage transformer.
If a DAC asks for a 7v - 9V power supply, should I used a 9v 2000 mA power supply, or ag8908 Digital Line Level 2 26th March 2014 06:24 PM
Making Symmetric Power Supply from Single with 4x ATX power Supply? lupetalo Power Supplies 11 20th November 2012 11:51 AM
Power supply positive-negative-ground from a single power supply mome Power Supplies 8 9th September 2011 05:17 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 01:30 PM
Copyright 1999-2017 diyAudio
