Floating PSU - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 8th September 2015, 10:18 AM   #1
merlin el mago's Avatar
Question Floating PSU
I'm sorry my ignorance, could I do a floating psu without batteries?
Old 8th September 2015, 11:51 AM   #2
Floating compared to what?
A simple transformer will detach it (make it float) unless you connect it to earth again.
If I'm right.
Old 8th September 2015, 02:29 PM   #3
So if I make a +- psu with 2 tx and 2 diode bridges and two caps and no connect 0V of positive rail and 0V of negative rail to nothing only together two 0V of the 2 psu is the psu floating right?
Old 8th September 2015, 03:09 PM   #4
A transformer gives you an isolated supply.
If you rectify and smooth that supply it is still isolated. The voltage limit on isolation is provided by the primary to secondary insulation. Mains transformers are usually short term guaranteed to >1kV, but i would not rely on any more than the maximum peak of the mains voltage rated for your transformer. For an EU 230Vac rated transformer that would be ~350Vpk.
It is how you connect that isolated supply that determines whether it remains isolated.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 8th September 2015, 03:17 PM   #5
rayma is offline rayma  United States
Yes, this has been done for many years, for example in the Circlotron amplifier circuit.
Just don't connect the supply to ground anywhere, and observe the voltage isolation
requirements, especially in the transformer and filter capacitors. Metal capacitor cans
(with or without insulation) would have to be isolated, for example.
Circlotron History
+/-floating tube PSU for guitar ?! Schematic error ? papasteack Instruments and Amps 11 29th August 2014 10:17 AM
CT Trafo and floating psu for circlotron? markusA Tubes / Valves 6 23rd August 2011 08:57 PM
Floating Cascode Stee Solid State 1 14th February 2010 11:30 AM
Floating the heaters YoungFred Tubes / Valves 2 16th September 2006 10:59 AM
Floating voltages eeka chu Parts 2 27th January 2004 09:10 AM
Copyright 1999-2017 diyAudio
