TL783, extending voltage range - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 20th August 2015, 07:31 PM   #1
Default TL783, extending voltage range
Hello everyone,
Here is a question for the more informed.
Is it possible to extend the range of a TL783 to regulate +175 to +200 vdc?
Is it as simple as putting a zener (75 volt) below the adj pot?
Max current 10ma.
Old 20th August 2015, 08:33 PM   #2
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
What's the application? The TL783 is a floating regulator (just like an LM317) so it's the difference between in and out that can't exceed 125V. This means you should be able to regulate 200V or higher as long as the in/out differential stays below 125V. In normal operating I expect it would be OK, but you of course lose the short-circuit protection.
/U.
DIY projects blog
Old 20th August 2015, 08:37 PM   #3
That might not be the best way to do that. Yes you can use a voltage
regulator at higher than it's rated voltage but when you do you usualy
would build a preregulator to limit the voltage across the regulator. In
that case you would be better off using a Lm317t on a 150v zener, Here
is an aplication note about this.
http://www.ti.com/lit/an/snva583/snva583.pdf
Old 20th August 2015, 09:25 PM   #4
You can use the LR8N3. It is a 480 volts regulator. Mouser part number 689-LR8N3-G .
Old 21st August 2015, 02:15 AM   #5
jackinnj's Avatar
LR8N3 will only dissipate 0.15mW in the TO92 package. It could be used driving the gate of a high voltage MOSFET, however. Maida solution is a nice idea which has been around for decades!
A preferential option for the poor, need not imply a preferential option for the state.
Old 21st August 2015, 02:09 PM   #6
Yes, You can not use it directly. You just use the LR8N3 to feed the adjustment output voltage to the gate of the mosfet. I also use the TL783 in this way.
Old 21st August 2015, 03:12 PM   #7
Look at the attached diagram fo a way to run the TL783 beyond 125V. Zener D3 pulls up the adj pin during startup. Together with D4 it also protects the regulator from any discharges during power down. Max input voltage variation (incl. ripple) is now limited to the zener voltage.
Note the minimum load current on the TL783 is 10mA at all times, iirc.
Extending the mid range? johncee1945 Multi-Way 12 4th January 2014 06:50 AM
Extending large bookshelves into full range (Midbass?) deadmau5 Full Range 0 18th April 2011 10:09 PM
Anyone used the TL783 as a CCS Shoog Tubes / Valves 2 25th September 2009 08:47 PM
Anyone who have used the TL783 ? beppe61 Power Supplies 17 16th September 2005 04:05 PM
Extending small drivers low frequency range with opamps? jsd Solid State 2 9th March 2004 06:41 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
