half bridge secondary voltage
Old 18th August 2015, 07:28 PM   #1
luixssj3 is offline luixssj3  Italy
Default half bridge secondary voltage
Hi to all
I have in mind to build a SMPS for a tube tester.
I considered half bridge topology and calculated the power transformer turns with the formula finded in Marty Brown book (you can see in the picture).
I have 66 turns primary and 270 turns secondary for 650V, 5 turns for 12,6V, 41 turns for 100V and 8 turns for 20V, repectively used for anodic voltage, filament, negative bias and aux voltage for SG3524.
Now if I understand well, the secondary of the anodic section has a turn ratio Ns/Np=4,09 so the voltage on this will be (230*1.41)*4=1297V!!
The filter inductor must drop 647V!!!
I think this can be a great problem for inductor dissipation and even for the insulation of the secondary...
What if I use a lower turn ratio? say only 2?
And what does happen if I use the 12,6V output to feedback the SG3524? the 650V secondary will have voltage variation as the load on the filament vary?
thanks in advance!
Luigi
Old 18th August 2015, 07:51 PM   #2
pergo is offline pergo  Italy
pergo's Avatar
No problem with turn ratio of 2.
You will get 440-480Vac, so 620-680Vdc when rectified full wave.
Nessuno può farvi sentire inferiori senza il vostro consenso
Mr.P Electronics
Old 18th August 2015, 08:19 PM   #3
Elvee is offline Elvee  Belgium
Elvee's Avatar
Half-bridge = voltage/2, which means you should be fine, taking into account inductive and other losses (won't be regulated though, and without any minimal bleeding, could rise to impressive voltage levels due to ringing)
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 18th August 2015, 09:39 PM   #4
mmmm I'm a bit confused...
In an example from Brown book I have a half bridge SMPS with 38 turns primary at 230Vac (324Vdc), a secondary of 5 turns for 28V (Ns/Np=0,131) and an aux secondary of 2 turns for 12V.
As I can see in the formula for the filter inductance, in the numerator appear (Vinmax-Vout), Vinmax is the raw output voltage given by the turn ratio and is 47V (in the picture), (230V*1.41)*0,131 = 42V ...
where is the error?!?
half bridge secondary voltageHide this!Advertise here!
SMPS Half-Bridge - High voltage ripple and large voltage drop dragondgold Power Supplies 91 18th December 2014 04:51 PM
Half bridge smps voltage drop problem alexclaire Power Supplies 66 4th October 2012 06:35 AM
half bridge SMPS secondary voltage drop problem ? alexclaire Power Supplies 6 10th November 2006 04:19 PM
