Speed control for 120vac fan that does not add noise - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 15th August 2015, 07:36 PM   #1
Default Speed control for 120vac fan that does not add noise
I have a 120vac window blower that I need to quiet down.
What type of speed control should I use (need at least 3 speeds) so that I am NOT adding any noise to my power lines?
Source?
Blower fan is 35watts, 120vac
thanks,
Herman
Old 15th August 2015, 08:15 PM   #2
vacuphile's Avatar
Variac
Old 15th August 2015, 08:17 PM   #3
nigelwright7557's Avatar
Switched resistors.
PCBCAD51 pcb design software. http://murtonpikesystems.azurewebsites.net/
Old 15th August 2015, 08:19 PM   #4
Anything chaper/more basic than Variac that will work? I need three speeds only...
Old 15th August 2015, 08:22 PM   #5
>>Switched resistors
can you recommend a ready to use box that has that?
Old 15th August 2015, 08:29 PM   #6
vacuphile's Avatar
Originally Posted by noviygera View Post
>>Switched resistors
Use a light bulb in series. Different wattages will provide different speeds.
Old 15th August 2015, 08:33 PM   #7
By a ceiling fan controller in the fan selling store. They have different sizes depending the fan.
Old 15th August 2015, 09:12 PM   #8
ceiling fan controller:
does it use switched resistors or transformer?
Old 15th August 2015, 09:51 PM   #9
vacuphile's Avatar
It puts hash on the line. The only el cheapo solution that doesn't do this light bulbs. It's a resistor, and part of a system of components that can handle high voltages safely.
Old 15th August 2015, 10:16 PM   #10
I have 4 fans that I used the fan controller to adjust the speed fan. I do not have any noise problems and the controller it is the one used a slide switch to adjust the speed of the fan. I bought them in Lowes. To install just remove the light switch for the fan and install the controller.
24V DC computer fan speed control Vrystaat Power Supplies 11 24th March 2012 12:01 PM
PWM fan control noise Aidan135711 Chip Amps 11 27th February 2008 06:19 PM
fan speed control flylionking Parts 6 27th June 2005 07:32 AM
Fan speed control jwb Parts 4 25th May 2004 05:33 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
