humming sound
humming sound
Old 11th August 2015, 07:34 PM   #1
harleyman58 is offline harleyman58  United States
Default humming sound
hi guys and gals
I have a problem with a humming sound. the receiver is a kenwood kr-v8060. I have sound to the speakers but the humming gets louder as I turn up the volume. I thought the filter caps were bad in the power supply. they were 7500uf 71 volt, replaced them with 10000uf 80 volt. still get the humming sound.
any thoughts
Kenny thank you
Old 12th August 2015, 02:57 PM   #2
DF96 is offline DF96  England
Generally, power supply reservoir caps being low in value would give a hum which does not increase with volume.
If the volume pot affects the hum then the hum is getting in at or before the volume pot. Do you have a circuit diagram? If so, can you read it? Do you have an oscilloscope and know how to use it?
Old 12th August 2015, 03:05 PM   #3
I do not have an oscilloscope. I can get and read a circuit diagram.
humming soundHide this!Advertise here!
Humming Sound from tube amp swlew Tubes / Valves 14 12th January 2014 05:57 PM
Humming sound after blown fuse justM Solid State 7 25th December 2013 08:11 AM
Kicker zx700.5 sub channel has humming sound and amp2 has echo like sound ivkata Car Audio 3 10th April 2012 09:23 PM
Humming and crackling sound jumpersg Solid State 2 29th March 2012 05:43 AM
Humming Sound From DAC Noak Digital Source 0 12th July 2006 02:39 AM
