Need wiring help for dual rail in R core - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 25th June 2015, 11:37 AM   #1
Default Need wiring help for dual rail in R core
Hi Friends.,
I have purchased r core transformer for my new preamp project. my point is r core having secondaries 2 x 9v, 2 x 15v (see image). i just need 15-0-15v dual power supply. Please help me for this issue.
thanks in advance
Old 25th June 2015, 12:28 PM   #2
JonSnell Electronic's Avatar
Send a message via Skype™ to JonSnell Electronic
Connect a yellow wire to a brown wire. That will be 0
The other yellow is 15
as is the other brown 15 giving you 15-0-15
If you get the wrong yellow, there will be nothing, swop the yellow wires. It will be pot luck.
Support for Flying Mole, Allen & Heath, Valve amps, older designs & 2CVs. www.jonsnell.co.uk
Old 26th June 2015, 08:38 PM   #3
do you need +-15Vdc?
you wrote
But that does not tell us anything !
regards Andrew T.
psu setup single rail, dual rail confusion.. trean27 Power Supplies 1 6th November 2014 09:14 AM
Dual rail secondary to single rail maouna Power Supplies 2 26th October 2013 09:05 PM
Can't Tell if Power Supply is Dual Rail Sh00pus Power Supplies 3 29th April 2013 12:21 AM
On/off switching dual rail Zoodle Power Supplies 1 29th December 2012 05:09 AM
softstart recommendation for 2kva R-core and 1,00,000uf per rail x 2 caps rhythmsandy Solid State 11 6th December 2012 01:57 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
