Audio Power Tranformer with 6 Primary Wires - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 25th June 2015, 01:18 AM   #1
ednja is offline ednja  Canada
Default Audio Power Tranformer with 6 Primary Wires
I have an audio power transformer with more than 2 primary wires. It has 6 primary wires and 6 secondary wires. Of the 6 primary wires, 2 of them are blue, 2 are red, 1 is purple and 1 is black. Does anyone know if there is a standard color code for these wires? How would these wires be connected to the AC?
Old 25th June 2015, 04:36 AM   #2
sangram is offline sangram  India
The best way to do this is to feed a small AC voltage from a known transformer into the secondary, and measure the voltage on the primary.
Each set of primaries will show a voltage, and you can calculate the winding ratio with measurements at both sides of the transformer.
Normally this would be either a set of 110 and 115V primaries, which are wired in series for 220 or 230V, or a similar combination for 100 and 120V. Other combinations are also possible. In some weird cases there may be a third primary winding, as I found in an old transformer once.
Old 25th June 2015, 05:46 AM   #3
First, you have to find out the coils by ohmmeter test. Then you can feed a safe voltage of 10Volts AC across one of the coil. Then make a series connection so that the voltages add up. This will give you the configuration for max primary voltage i.e. 240 Volts AC.
Gajanan Phadte
Old 27th June 2015, 09:04 AM   #4
is this a mains power transformer?
or
an audio transformer?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 27th June 2015, 12:20 PM   #5
It's a mains transformer.
Old 27th June 2015, 02:16 PM   #6
identify each separate winding. find all the taps on each winding.
Label them.
I prefer to insert each wire end into separate receptacles of an insulated terminal strip.
It stops you accidentally touching/shorting a loose wire.
It cuts through the insulating tough varnish/enamel covering the ends.
It allows you to insert links to tie separate windings together - safely.
Measure the resistance of every tap. This will identify whether you have a 0-100-110-120Vac winding or a 0-55-110-120Vac winding. And get them in the right order
connecting 110Vac to 0-110 of a 0-110-120Vac is very different from connecting 110Vac to 0-10 of a 0-10-120Vac winding. One blows up, the other survives !!!!!
regards Andrew T.
Zobel network at primary audio trafo? hego Tubes / Valves 2 30th March 2014 08:41 PM
Can MOV (varistors) be wired to each primary in a universal dual-primary transformer? fualcr Power Supplies 2 11th November 2012 01:34 AM
transformer primary wires - identification pheonix358 Power Supplies 5 6th October 2009 10:37 AM
need power tranformer ideas luthierwnc Tubes / Valves 8 18th December 2007 08:38 AM
Conductors (I.C.'s, RCAs, internal wires, speaker wires) bigphil Parts 1 25th November 2005 06:47 PM
Copyright 1999-2017 diyAudio
