Cooling of bridge rectifier - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 15th June 2015, 07:26 AM   #1
sajti is offline sajti  Hungary
Default Cooling of bridge rectifier
I'm working on a high power amplifier. I will use Vishay PB5008 rectifier, which is PCB mounted version. My question is the cooling.
Most of the high current rectifier is the usual square metal case version, with 6.3mm connectors. And these are mainly fixed on the box of the amplifier.
The PB5008 is designed to attach to heatsink. I found some solution using small attachable aluminium heatsinks. This solutions looks weak to me, as the datasheet define the dissipation, which can be up to 80-100W with high current.
Is there anybody who use this type of rectifier? How to cool it? Is the small heatsink is enough?
Thanks:Sajti
Old 15th June 2015, 07:50 AM   #2
Did it Himself
richie00boy's Avatar
"High power amplifier" - how high? I would say that any more than 200W into 4 ohms and you need to be using either low Vf diodes or a case-mounted block to get rid of the heat.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 15th June 2015, 07:52 AM   #3
It will be 2x600W/4ohm.
Sajti
Old 15th June 2015, 09:14 AM   #4
JonSnell Electronic's Avatar
Send a message via Skype™ to JonSnell Electronic
That means the rectifier will be dissipating about 12Watts at full load.
Hardly worth worrying about. A 12W/degree heat sink will keep it well below 70C.
Support for Flying Mole, Allen & Heath, Valve amps, older designs & 2CVs. www.jonsnell.co.uk
Old 15th June 2015, 09:25 AM   #5
MarianB is offline MarianB  Romania
MarianB's Avatar
Send a message via Yahoo to MarianB
I'd say it's more like 20W or so power lost on the rectifier, that is not negligible, at that power the case still can safely reach a high enough temperature without fail ( according to it's datasheet ), still it needs a good heatsink, 20W are not very easy to get rid of. I think it would be better to mount it on the amplifier case and connect it with wires to the board, because fitting an heatsink capable to dissipate 20W on the board may not be easy or even possible.
Have a go at my latest set => Trance Session Live ep 67
Old 15th June 2015, 09:48 AM   #6
the datasheet shows about 40W dissipation for 22A rectified current. It needs about 0.8K/W heatsink to dissipate.
Sajti
Old 15th June 2015, 09:49 AM   #7
I want to avoid it, as I choose this rectifier to reduce the internal cabling in the amplifier.
Sajti
Old 15th June 2015, 09:57 AM   #8
MarianB's Avatar
For 600W onto 4 Ohms you would have about 11A for both channels, so about 20W of power loss on the rectifier. As for what size of a heatsink is needed and what can be fitted on to the board, they may be 2 different things, it depends on your supply board, it's layout and size. You could design it as so the rectifier bridge gets positioned on the side, so you can actually fix it on the case or on some big enough heatsink.
Old 15th June 2015, 10:00 AM   #9
That is true, sorry it was my mistake with the calculation.
Sajti
Old 15th June 2015, 10:02 AM   #10
MarianB's Avatar
No problem, everyone makes mistakes at some point...
Do you already have the supply board fitted, or it is still on the drawing board?
Bridge rectifier vs Full wave rectifier hilbert_mostert Tubes / Valves 4 28th April 2009 08:26 PM
Integrated Rectifier Bridge VS Rectifier Diodes Sci Chip Amps 11 16th July 2004 02:43 PM
rectifier cooling... kasra Pass Labs 7 20th December 2003 01:02 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
