Asking about Power supply #PS1 of Audible Illusions - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 13th June 2015, 01:53 PM   #1
wsyoo1 is offline wsyoo1  South Korea
Default Asking about Power supply #PS1 of Audible Illusions
I have Audible Illusions Modulus L1 Preamplifier with power supply #PS1.
This power supply works on 120V.
We use 220v in my country, and I heard that the power supply can be used on 220v if the jumper inside the power supply is desolered or soldered. However, I don't know how to do it. So, would you please let me know the desoldering or soldering method.
For your reference, I am attaching the picture of jumper inside the present power supply working on 120v. Thank you.
Old 13th June 2015, 02:42 PM   #2
Keruskerfuerst's Avatar
Can you give a bigger picture of the psu especially of the transformer?
Old 13th June 2015, 03:15 PM   #3
Default attachment of bigger picture
Thank you for you reply.
I herewith attached the bigger inside picture of power supply.
Old 13th June 2015, 03:41 PM   #4
Old 14th June 2015, 04:46 AM   #5
I herewith attached again bigger pictures of the psu of the power supply PS1. Hve a nice day !
Old 14th June 2015, 07:03 AM   #6
Usually the output coil of the transformer must be changed.
I donīt see any spare coils (of the transformer) for that.
Old 14th June 2015, 07:44 AM   #7
I can not find spare cables of output side of the coil.
Moreover, there are only two cables of input side of the coil.
I guess there is no way to use on 220v just by desoldering or solderingof the jumper.
It is used only on 120v.
Thanks for your kind concern in this matter.
Old 14th June 2015, 10:26 AM   #8
Can you check the wiring of the twisted THREE wires passing through the black insulating tube?
Are these the Mains input wires, brn/brn/yel ?
At the other end, they are TWO wires, blk/wht
There is a join inside the insulating tube.
If the transformer is a single primary, you must use the original Mains voltage.
If the transformer is a centre tapped primary, you will have a choice of supply voltage.
If the transformer is a dual primary, you will have a choice of supply voltage AND retain full VA capability.
regards Andrew T.
Old 14th June 2015, 11:40 AM   #9
Ghianni is offline Ghianni  Greece
Right!
If there is inside no other wire then the transformer is only for 120VAC and must be replaced for a 220VAC one...
If there is a third or more wires...just inform us.
Old 14th June 2015, 12:11 PM   #10
As I marked, blk/wht cables are 120v mail input cables and they go inside to the coil through blk insulating tube. And brn/brn, red/red., brn/brn/yel cables are coming out from the coil. Of course, brn/brn/yel cable and blk/wht cable is not joined. I don't know if they are simple primary, centro tapped primary, dual primary or not.
Thanks to Andrew T and Ghianni
Audible Illusions and 6922 pforeman Tubes / Valves 28 8th June 2014 07:17 PM
Audible Illusions L1 background noise MVZIK Analog Line Level 0 24th February 2014 12:07 PM
Reducing gain on Audible Illusions M3A no xo Tubes / Valves 4 27th August 2007 05:27 PM
Audible Illusions Modulus faulty? st2_998 Tubes / Valves 4 25th August 2007 02:20 PM
input caps in an Audible Illusions M3 funnyjoe Digital Source 0 24th October 2004 05:58 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright Đ1999-2015 diyAudio
