Induced buzz in Hammond 374bx - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 11th May 2015, 02:26 AM   #1
Default Induced buzz in Hammond 374bx
I posted this in the Tubelab forum, but no answers.
The 374bx on my Tubelab SSE has been giving off a mechanical buzz. In order to try to trace the source, I disconnected an optional 85uF Claritycap that is designed for psu smoothing. The buzzing stopped.
The capacitor is glued side-on to the underside of the chassis top plate. The Hammond power trafo sits directly above it on the topside of the aluminum top plate.
To me, it implies some kind of electromagnetic inductive coupling between the trafo and capacitor.
Wonder if anyone has experience of this?
Thanks,
Charlie
Old 11th May 2015, 03:53 AM   #2
rayma is offline rayma  United States
It may be that the large value cap is too much for the power supply. Also, could a rectifier tube be buzzing instead?
Old 11th May 2015, 05:33 AM   #3
Rayma,
I am pretty sure it's not the rectifier tube as the buzz is gone with the capacitor removed and rectifier tube in place. Also other builders have used 80uF caps in the SimpleSE.
Charlie
Old 11th May 2015, 01:17 PM   #4
Magz is offline Magz  United States
I don't think it's coupling. Hammonds tend to buzz. Either decrease the cap, go to a choke input design, or slide some Deflex/sorbothane material under the transformer mounting to quiet it down.
I've also had luck jamming some popsicle-stick or other wood into the gap between the bobbin and the center leg of the E laminations. Sounds weird but it works.
On the fast lane of the street I'm driving, sometimes, somewhere, I'm arriving. Every day and every night.
Old 11th May 2015, 02:52 PM   #5
Ok, then try a similar value cap located a few inches away. This will show whether the problem is the uF value or the location.
Are there bolts on the transformer that you can tighten?
Source of mechanical buzz in Hammond 374bx cbutterworth Tubelab 3 16th May 2015 07:00 AM
FS (UK) Hammond 374BX Power Transformer vinodt1347 Swap Meet 6 23rd November 2014 04:50 PM
FS (UK) - Power Transformer Hammond 374BX vinodt1347 Swap Meet 5 8th October 2013 12:43 PM
Hammond Pwr Trans 374BX Diagnosis Junior Tubelab 19 18th September 2012 04:00 PM
Hammond Power Transformer Buzz... Guiness Tubes / Valves 29 28th June 2008 01:51 AM
Copyright 1999-2017 diyAudio
