Duncan Amps PSU II: Locked Files
Old 26th April 2015, 01:11 PM   #1
richard8976 is offline richard8976  United Kingdom
Default Duncan Amps PSU II: Locked Files
Hi. I created a circuit and saved it in C:/Program Files/Duncan Amplification/Power Supply Designer II/Examples.
But, the thing is, the saved file has a lock symbol on the icon for the new file I created. And that stops me from moving the file to a new location. In fact I can only see the new file using PSU Designer II - it's invisible to Windows (even when I have ticked "Show hidden files, folders and drives").
I tried messing about with ownership of the file, but I could not change anything, because Windows 7 reports: " Unable to set new owner on <File Specified> . The System cannot find the file specified."
I then navigated Properties>Details and at the bottom of the Details tab is a link of sorts named "Remove Properties and Personal Information". I clicked on that and made sure "Create a copy with all possible properties removed" was ticked.
When I clicked on OK, I got a copy of the file. This time with no lock. Then I could move it to a new location.
Old 26th April 2015, 11:19 PM   #2
mcandmar is offline mcandmar
I have similar issues in Window 8.1, bunch of files saved in the C:/Program Files/Duncan Amplification/Power Supply Designer II/ however when i open Windows Explorer they aren't visible. Tried your trick above which does duplicate the files, but still cant see them in Explorer.
Old 7th May 2015, 09:35 AM   #3
ClassC is offline ClassC  New Zealand
Was the application that created the file running when you tried to copy/move?? Most prgms will lock their files while they its running. If so close the prgm.. Just my 2c
My karma just ran over your dogma..
Duncan Amps PSU II: Locked FilesHide this!Advertise here!
Estimating load for Duncan Amps PSU tool HOWTO? Blue Jinn Tubes / Valves 43 9th February 2017 06:52 PM
Duncan amps PSU designer II help famousmockingbird Power Supplies 25 9th September 2011 03:20 PM
Duncan Designer II - Use of richard8976 Power Supplies 5 7th June 2011 09:22 PM
Duncan Amps PSU Designer II rsumperl Tubes / Valves 2 17th January 2011 06:23 AM
Duncan PSU Designer II MattM Pass Labs 2 2nd February 2005 09:24 AM
Copyright ©1999-2017 diyAudio
