Look ma, no center tap
Old 13th April 2015, 05:23 PM   #1
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Default Look ma, no center tap
Retrofitting an LM4780 chip amp into an old Fisher Console -- no CT on the power transformer. This works as a rail-splitter for a more demanding load:
Old 14th April 2015, 02:33 PM   #2
DF96 is offline DF96  England
Are you sure? What do the upper three diodes do? As wired, not what the lower three diodes do!
Old 14th April 2015, 02:50 PM   #3
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Jack, the real test here is with asymmetrical loads. Load it so that the pos side needs, say, 3A and the neg side 0.3A Then see what happens.
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 14th April 2015, 03:02 PM   #4
wwenze is offline wwenze  Singapore
A rail splitter is essentially an amplifier that outputs a "nothing"
Or, you can run your LM4780 in bridged mode so that negative terminal can output something more useful. That's how the cheap stuff are powering their speakers, because bipolar supplies are expensive.
Old 14th April 2015, 07:29 PM   #5
Ketje is offline Ketje  Belgium
Ketje's Avatar
The datasheet of the LM4780 shows how to use it with a single supply.
Mona
Old 16th April 2015, 06:31 AM   #6
palstanturhin is offline palstanturhin  Finland
palstanturhin's Avatar
Virtual ground.
Old 21st April 2015, 07:04 PM   #7
jackinnj's Avatar
Jan
How about a nice muscular servo? Are you hinting at Figure 2 of LA#9's article "Low Parts Count Amplifier"?
Old 21st April 2015, 07:27 PM   #8
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
-RNM
Old 27th April 2015, 06:09 PM   #9
Binely is offline Binely  United States
Binely's Avatar
I have an old fisher tuner I would be interested in retrofitting too. Uses a couple of old sanyo IC's. Interested in collaborating?
Look ma, no center tapHide this!Advertise here!
Half B+ taken from center tap kaputt Power Supplies 4 14th August 2014 12:31 PM
Center tap or not... ixe13 Tubes / Valves 7 8th April 2011 11:14 PM
Center tap wiring tom wesley Chip Amps 3 11th July 2010 07:34 PM
No center tap Help FastEddy Power Supplies 57 19th April 2010 07:01 PM
Transformer Center Tap dswiston Parts 2 4th February 2004 03:09 PM
