Hi!
I'm in the process of building a rectifier for the power supply section of an amplifier I'm building, using a 55VAC 625VA toroidal transformer.
It is going to be used to power the Sure 2x125W IRS2092-based board. I was originally planning to build the rectifier myself, using power diodes, but I see Sure Electronics has a premade board that looks tempting... Two actually.
So my question is - are the Sure Electronics rectifier boards a good solution, with a sane choice of components? I see it uses STTH1602C High frequency ultrafast diodes - are these any good for a toroidal transformer?
These are the boards in question:
Sure Electronics' webstore 20A/75V 18,800Uf Rectifier Board ? STTH1602CFP
Sure Electronics' webstore 20A/100V 37,600Uf Rectifier Board ? STTH1602CFP
I see, maybe I should go for the readymade board then, and instead concentrate on making a DIY voltage regulator to put between the rectifier and amplifier board.
Would the 20/75V 18.800uF version of the Sure rectifier board be adequate for the Sure version of IRAUDAMP7s, or should I go for the larger 20A/100V 36.600uF version? The toroidal transformer I'm about to order is this 50V one:
VTX-146-500-150 - MULTICOMP VTX-146-500-150 - TRANSFORMER, 500VA, 2X 50V | Norge
or maybe this one (but more expensive, and 55VAC - might be too much for the IRAUDAMP7s, as it will become about 77VDC?)
MCTA500/55 - MULTICOMP MCTA500/55 - TRANSFORMER, TOROIDAL, 2 X 55V, 500VA | Norge
Please bear with me for asking these basic questions, this is my first DIY amp.
