Isolated from earth. I assume that two quite separate PSU boxes are otherwise isolated from each other.sonofbonzo said:do you mean isolated from the earth or from each other?
This suggests it is really a -24 0 +24 supply. However, which voltage falls? You need to remember that every voltage is between two points, but usually we measure voltage from earth. The output you earth must be at 0V from earth. So are you saying that connecting one terminal to earth makes the other terminal drop its voltage too?If I connect either of the outputs to earth the voltage falls from approx 7v to zero after a few seconds.
'Single output' may mean 0-48V supply.I have looked at meanwell site and it show this as a single output does this mean 48V or 24 0 24?
I think you need to contact them and ask.
I just had a closer look at my RS-75-12 and this one has an output that is completely isolated from earth. Its block diagram is exactly the same as your RS-150-48.
By "connecting across" in the last sentence you mean put a meter across it and not short circuit it, right?
Not sure if this helps.
when I connect across the + and - signs I get 49 volts dc
Thanks everyone for your input. I decided on the suck it and see method, hooked em up as intended and stood back. Nothing happened and I now have a 48-0-48 supply.
As this approach seems quite usable I will now buy the nice cheap meanwell supplies.
Anyway they are now for sale with the Nu Force monos...There wasn't enough grunt for my Cold Amp units.
- Power Supplies
- Stupid Question?
