Is this better then 78** and the rest of the family?
5V, 300mA Step-Down Voltage Regulator D24V3F5 | 2098 | Pololu
Low Cost 3 pin Switching Regulator 5V 1A
I know that there are SPower Voltage Regs and rest. But I'm looking for a bit cheaper.
Is LM317 better then this voltag regulators?
Is an analog reg better than a switcher?
Those switching regulators probably have poor filtering at the output.Residues of the switching ask for additional filtering if used for audio, makes it not that cheap.
On the other hand, if the voltage drop is big the LM317 gets hot, more cost on cooling and more power wasted then a switcher.
So what is best ? It depends...
Mona
Mona
A zener diode ?How to use 3 pin regulator? I didn't use this before. I used 2 pin regulator.
Mona
Is there a 3 pin regulator under 10$ that have a good filtration!?
$10 for a 3-pin reg?? They should not be more than a buck, or even less! Unless you need an 8 or 10 amp one.
BTW A regular 3-pin reg doesn't filter - it is a DC feedback amplifier that amplifies a stable reference voltage.
Jan
Jan
Charge applicable if I want touse 3 pin regulator.
- Power Supplies
- Three pin voltage regulator
