Noisy amplifier?power supply - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 18th February 2015, 12:03 AM   #1
bullpeters's Avatar
Default Noisy amplifier?power supply
Can anyone walk me thru, or point me to a tutorial for finding and diagnosing Noise in amplifiers/power supplies? Using an Oscilloscope?
I have a very noisy valve guitar amplifier. That is, when its turned on and the volume is past 10 o'clock, there is a lot of unpleasant noise. Its volume dependant. i have poked a wiggled everything, confident of layout and grounding, regulated every thing (B+ heaters etc). I am hoping that i can see the noise on an oscilliscope and identify it.
So, where can i learn to do this?
Old 18th February 2015, 12:05 AM   #2
rayma is offline rayma  United States
Can you post the schematic and some good photos?
Old 18th February 2015, 03:22 AM   #3
bullpeters's Avatar
i would rather someone point me to or provide a method to investigate the display on a scope to give me a hint as to whats causing it. that way not just being relative to THIS amplifier. I have tried the obvious.
thanks
Old 18th February 2015, 09:15 AM   #4
DF96 is offline DF96  England
Get the circuit diagram, or reverse engineer it from the item itself. Note the major stages, and roughly calculate the gain of each stage. Use the scope to see where there is noise, and where there is not noise - taking into account the gains you just calculated. The noise probably originates at or just before the earliest point in the circuit where you can see it.
If appropriate, disconnect any feedback loop. If the noise is only present part of the time, note when it is present and when it is not present. From that work out what might be causing it.
Almost any component can cause noise. In old equipment suspect carbon composition resistors.
PS I assumed that when you say "noise" you actually mean noise, and not hum or oscillation. However, fault tracing (or is this debugging of a new build - you haven't told us) is much the same whatever the problem. It involves comparing what the circuit does, with what it is supposed to do. The big difference is that in debugging the circuit itself might be wrong, whereas in fault-tracing it is a component (or joint).
Old 18th February 2015, 09:18 AM   #5
Max Headroom's Avatar
Location: West Australia, near to the beach, natural ambient sounds only.
If the noise is volume dependent you should see it by connecting your CRO probe to the 'top' of the volume pot.
What is the nature of the noise ?.
You could make a short recording of the sound, encode it to MP3 (128k mono would be good enough), compress to ZIP file and attach to your post...max file size is 975 kB.
Dan.
Harmonic distortion is not the arbiter, other factors are the *rse biters .
Just how noisy is a switched mode power supply? mcandmar Power Supplies 0 27th September 2013 02:02 AM
alteration of the power supply from the power amplifier Harman Kardon HK870 at 220. alexkmp3 Power Supplies 4 11th December 2012 04:39 PM
Noisy DC filament power supply problem on an Aikido Captn Dave Tubes / Valves 14 28th September 2009 07:06 PM
noisy laptop power supply CBS240 Power Supplies 1 7th February 2007 09:46 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
