PCB hole with solder current rating. need confirm? - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 29th January 2015, 03:22 PM   #1
obscurus's Avatar
Default PCB hole with solder current rating. need confirm?
In my PSU PCB there is a pad between two side of the board to pass current from big caps . Diameter is 1.5mm. It was filled with solder paste.
This is my caculate:
Circle area = d2 / 2 * pi = 1.5 * 1.5 * 3.14 / 2 = 3.53 mm2
So if copper thickness = 1oz = 0.035mm -> it is the same as copper with width = 3.53 / 0.035 = 100mm
So it can pass a lot of current? Am I right?
Old 29th January 2015, 03:54 PM   #2
RJM1 is offline RJM1  United States
Look here.
The CircuitCalculator.com Blog PCB Via Calculator
Old 29th January 2015, 04:32 PM   #3
obscurus's Avatar
Originally Posted by RJM1 View Post
Thanks! That's help my problem. I also found add solder to that holes make no diferent because solder resistance ~ 10x bigger than copper.
Old 31st January 2015, 09:39 AM   #4
Pi*D = circumference
Pi * RČ = area
D/2 * Pi = half of the circumference !
Area of the annual ring of a through plated hole = Pi * {DČ-dČ} / 4 where D = outer diameter and d = inner diameter.
regards Andrew T.
PCB Through Hole Repair crazifunguy Parts 6 19th October 2011 03:54 AM
Solder through-hole penetration? Drew Eckhardt Everything Else 5 20th November 2006 02:18 AM
Current rating and tube current draw cbutterworth Tubes / Valves 1 13th October 2006 05:42 AM
PCB Trace Width Current rating?? Zero Cool Everything Else 9 21st November 2004 08:48 PM
Transformer VA Rating vs. Current Rating JhonDoe Chip Amps 45 5th June 2004 02:11 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
