Transformers position
I have a rebel hum in either Ouput transformers.This hum is yet without the valves in sockets.I think is a direct coupled at the OT from the mains power transformer field.
What´s the right positions and mínimal distance between the transfromes?
I use now a 90 degrees and "X" mount for OT, and "Z" for power trafo.
Thank´s
Thank´s
The distance between the OT´s and main power trafo is only 10 mm.If add only 2 mm more (total 12mm ) this hum level is very... very low.
I think the solution is add more distance, minimal about 20 or 25 mm.
I used also copper shield around the coils of trafos without success.
Cheers
Cheers
