Another Odd Power Transformer - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 10th January 2015, 05:37 PM   #1
Default Another Odd Power Transformer
This is from a solid-state stereo receiver.
My mains voltage is 124 VAC, give or take.
I measured the DC resistance and checked continuity on all wires to be sure I had some idea what I was doing before putting it on AC mains (I also checked with a simple 12 VAC wall-wart power supply first to be safe).
This transformer is simply huge! I have it posed next to a Type 80 rectifier tube for reference; also my hand is not exactly small. It must weigh a good 8 to 10 pounds; very hefty.
Secondaries:
80 VCT (very thick wires, as thick as primaries)
40 VCT (thin wires)
20 VCT (thin wires)
4.6 VCT (thin wires)
There was one odd wire that didn't appear to be 'grouped' with any of the above, but as it turned out, it seems to be a bias tap for the 20 VCT group. Taken with either of the 10-0-10 ends, it gives 16 volts. Not sure what that's all about.
So, given this, I am trying to figure out how or if I can us it in a tube amp design. I thought perhaps with a doubler circuit, I could use the 'thick' secondaries for B+ on a low B+ style amp, or perhaps as heater voltage on some of my famous 50 volt heater tubes that I so love (because they are cheap).
On the other hand, perhaps I should reserve this monster for use on a Class D solid-state amp, something that could use the massive amperage this transformer must be shoving out.
Thoughts?
Thanks!
Odd/Crazy output transformer design? Matt BH Tubes / Valves 112 18th September 2012 10:23 AM
Odd transformer wiring dscottguitars Instruments and Amps 7 11th March 2012 01:17 AM
Odd transformer behavior badman Everything Else 3 23rd August 2006 08:03 PM
I have an odd transformer issue (want to build the gainclone) Jerry Parker Chip Amps 9 22nd October 2003 01:37 AM
odd transformer design godfather_cz Parts 7 3rd May 2003 11:32 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
