help on lt1085 dropping voltage on load - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 17th December 2014, 09:00 AM   #1
Default help on lt1085 dropping voltage on load
Anyone can shed light, measuring of load i can adjust the lt1085 with turn pot just fine.
When i set it to say 13v without load, once small load is connected voltage drops to 2v or so
Im using a ebay lm317 board and did put a 10000uf cap at the input
Please anyone can chime in.
Old 17th December 2014, 01:00 PM   #2
DUG is offline DUG  Canada
Schematic?
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 17th December 2014, 01:29 PM   #3
jackinnj's Avatar
The regulator will drop out if (Vin-Vout)*Iload is too high, and it isn't heat sinked.
The LT1083,4,5 family are quasi "low-drop out regulators" (LDO) and as such needs a capacitor on the output for stability. 100uF aluminum electrolytic should be Ok. See Linear Tech's data sheet.
Old 17th December 2014, 02:24 PM   #4
its a basic design with turnpot for adjust and a cap at output.
even connecting to power a 3.3v regulator not connected to any load causes a drop.
it fine without amything connected.
vin 22v load i am powering maybe 13v, 1 - 2 a.
big heatsink but not warm, just drops on anything connected.
Old 17th December 2014, 02:32 PM   #5
analog_sa's Avatar
You probably realise that provided there are no faulty connections or fake chips, this behaiviour is quite impossible.
Old 18th December 2014, 03:38 AM   #6
Schematic?
Old 18th December 2014, 04:51 AM   #7
You need at least 100uf on the output or it drops out
Old 18th December 2014, 05:36 AM   #8
DUG,
sorry i purchased the board from ebay (very basis design), it is a lm317 reg so i swapped it out. Basic bridge to a cap to Vin, 1 resistor 22uf cap and a pot.from Vout and V adj.
ticknpop,
Thanks you are right that i studied the schematic for the LT1085 it need a cap at output which the board doesnt have. I have placed a 2200uf cap but frustratingly, it is the same.
The Lt was purchased from element14 so not a fake, could it be damaged. This is the 2nd LT one i replaced. FWIW, may not be the reg.
The adj resistor is a 1/4w, could this be causing the problem?
Thanks once again.
Old 18th December 2014, 12:39 PM   #9
Bought on ebay !
ask the retailer for customer support !
regards Andrew T.
Old 18th December 2014, 02:09 PM   #10
Is the single resistor 120R or 240R?
These regulators need a minimum load so 120R is recommended...otherwise the output voltage will rise above what is set and will go back to a regulation point when minimum current requirements are met.
The pot should be as shown, not from Vout to Vadj.
See .jpg (caps not shown)
Dropping voltage on 12v battery Tcoil Power Supplies 8 6th February 2012 01:20 AM
dropping heater voltage jarthel Tubes / Valves 17 21st September 2006 05:50 AM
Why is my MOSFET dropping so much voltage? arnoldc Power Supplies 19 21st April 2006 08:52 AM
The LT1085 voltage regulator Ryssen Parts 6 30th January 2004 11:31 PM
Maximum input voltage of LT1085 & LT1033 chengtaw Solid State 2 8th January 2003 04:27 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
