Replacing Mallory CGS capacitors in an APT power amp - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 7th December 2014, 09:56 PM   #1
Default Replacing Mallory CGS capacitors in an APT power amp
Hi
I have an APT power amp which I am refurbishing, and it has 2 Mallory 10000uf 75v electrolytic caps in the power supply.
I have measured both out of circuit with the neat Peak ESR 70 and both have Zero ESR, one has capacitance of 10,480uf and the other 11,780uf. Having tried to decipher the codes on the cans I think these were made in 1980, and as they are 30+ years old could/should be replaced.
Given thier size, there a couple of alternatives, some Nichicon 10k uf 80v and 100v @85c and another larger Nichicon 10k uf 80v @ 105c- however all of these are +/- 20% whereas the Cornell Dublier CGS series (which I am assuming is the descendant/replacement for the Mallory) is -10%/+75%.
so would I be better off the the CD CGS series or the Nichicon and does it matter?
and secondly would one be wise to add a (say) 1uf 250v decoupling film cap (say a panasonic) across these?
any assistance and guidance appreciated
Peter
btw photos attached
Old 11th December 2014, 07:51 PM   #2
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
i'd used the higher temp rated parts and call it a day.
as for the extra bypass cap, i think you'd get more bag for the buck with a R-C snubber across the transformer secondaries or across the power supply rectifiers, but that's just me.
nice amp, btw. i used to have one years ago. lost it due to a lightning strike that caused a fire when i was out traveling for work.
does yours hisssss?
btw2: there's a thread here somewhere where one of the techs and original designer for the amp discuss it's performance, which was quite good for its day (and still is in a lot of ways).
mlloyd1
Replacing capacitors on Audio Research D40 power amp. audiojack123 Tubes / Valves 4 31st July 2012 01:05 PM
Replacing capacitors on Audio Research D40 power amp. audiojack123 Tubes / Valves 0 30th July 2012 07:47 PM
replacing power supply capacitors dansemacabre Solid State 4 15th December 2010 04:15 AM
Replacing power supply capacitors nicksmurf Solid State 13 16th October 2009 01:42 AM
Mallory CGS Cap sippo Swap Meet 3 24th December 2004 11:47 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
