100 VOLT 20 AMPERE POWER SUPPLY - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 30th November 2014, 06:10 PM   #1
Default 100 VOLT 20 AMPERE POWER SUPPLY
we are thinking to use maida configuration of lm317 but we couldnt decide how to increase the current value to 20 A. here is the link of maida configuration http://www.ti.com/lit/an/snoa648/snoa648.pdf
Any help will be apreciated.
Old 30th November 2014, 09:50 PM   #2
WSJ is offline WSJ  United States
WSJ's Avatar
This SCR pre-regulator keeps the filter capacitor Vc, in a variable output power supply, a few volts above the output voltage V0.
Preregulator for Power Supply Circuit Diagram | Electronic Circuit Diagrams & Schematics
http://powersupply.blogs.keysight.co...regulator.html
6 or 12 Volt Power Amplifier with Bluetooth
http://www.thesamba.com/vw/classifie....php?id=796241
Old 30th November 2014, 10:25 PM   #3
DUG is offline DUG  Canada
It gets complicated but here is how to increase current capability and include current limiting as well.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 30th November 2014, 10:27 PM   #4
WSJ's Avatar
The HP 6286A power supply uses a tracking preregulator.
http://physics.ucsd.edu/neurophysics...ice_Manual.pdf
Old 2nd December 2014, 04:34 PM   #5
thanks for your answers i will check those infos . ı wıll return ıf ı had a good solutıon for my problem
Help converting 13.5 volt ac to 20 volt majod Power Supplies 2 18th December 2013 05:41 AM
12 volt power supply stoppage Power Supplies 19 27th September 2013 09:55 PM
100 volt 10 ampere dv voltage regulator for split supply livenicely Power Supplies 0 19th November 2009 12:17 PM
Need Help with + _ 90-100 volt regulated power supplies wrich22 Power Supplies 4 21st March 2008 10:46 PM
DH-500 +- 90- 100 volt Regualted power supplies wrich22 Solid State 0 21st March 2008 10:13 PM
Copyright 1999-2017 diyAudio
