Shunt current regulator - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 29th November 2014, 02:51 AM   #1
Default Shunt current regulator
Hello!
Does anyone have schema of shunt regulator for DACs chip. For example for AVCC lines of ES9018 chip. Main feature of this regulator is that it must has extremely low impedance. It is good choice tentlabs shunt regulator Shunt Regulator . Impedance is 10 m-Ohms over total bandwidth.
This is some photos of tentlabs shunt
May be some Salas regulator schema's will be ok (but those schema's for high current power and high voltage usually). Could anyone suggest schema?
Old 29th November 2014, 11:00 AM   #2
All Shunt Regulators must have a pre-selected maximum current.
All Shunt Regulators will have a Vdrop that is much higher than an LDO type regulator.
All Shunt Regulators will waste some current that does not pass through the load.
The Salas and the Tent will be no different in those respects.
regards Andrew T.
Old 29th November 2014, 11:24 AM   #3
Salas regulators too much high current (those in Group Buy). For AVCC of ES9018 chip needed only 100-150 mA 3.3V and 1.2V. And the main feature for power of ES9018 is low impedance on bandwidth from 10Hz to 50KHz. Does Salas regulator has low impedance (10m-Ohm or so) ? And such low impedance must be on all sounds bandwidth (as I wrote 10Hz - 50KHz).
Shunt Regulator variations (Parallel voltage regulator variations) for SS Pre-Amp tiefbassuebertr Solid State 2 15th December 2012 11:09 AM
Shunt Regulator PoweRex Power Supplies 1 22nd July 2011 11:53 AM
Crazy Current Mode Shunt Regulator wrenchone Analogue Source 5 30th November 2010 07:18 PM
How about shunt regulatorH uhcmos Solid State 4 2nd March 2007 10:32 AM
Shunt regulator tubee Tubes / Valves 12 2nd March 2006 02:08 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
