How much power do I need? - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old Yesterday, 02:35 AM   #1
Default How much power do I need?
Hello everyone, I'm new of this so I hope to write this post in the correct section, Basically I need to power my audio rack which has 3 amplifier rated at 15A power consumption and output power stereo RMS @4ohm 2x1200W, one crossover, 2 turntable , 2cdj, 1 laptop, 1 dj mixer, which main supply do I need to run everything smoothly? 16A? 32A?
Any help/advice will be more than welcome as I don't have any knowledge about electricity, many thanks
Old Yesterday, 03:15 AM   #2
rayma is offline rayma  United States
If each amp potentially draws a maximum of 15A of current, then you need 45A capacity total. The rest of the equipment can be neglected.
Make sure that the circuit you plug this into can supply this amount, or you will trip breakers or blow fuses. You probably will need to use
more than one circuit to supply the power.
Old Yesterday, 07:01 AM   #3
trobbins's Avatar
Some of the questions you need to ask yourself may include:
Do I just focus on the power amps, as all the other equipment really only draws a relatively minor level of power from the mains?
How does my power amp draw power from the mains, because it might use a unity power factor power supply or it might use a simple rectifier with capacitor input DC type power supply?
Have I read my amplifier specification properly, and either contacted the amp maker or done a sample rms current measurement on one amp when it is putting through the worst-case sound level I want it to do ?
What is the short-term average power that would actually be sent to the speakers, as it could need speakers rated at a combined 2x3x1200 = 7,200W ?
What options do I have for mains connections, as it could be 1 ph, 2ph, 3ph ?
Old Yesterday, 07:32 AM   #4
Chances are you'll never pull more than 30 amps but I'd check my in use current to be sure.
Old Yesterday, 03:50 PM   #5
Many thanks for the quick response, so a PDU with main supply at 32A like this is not enough to run everything?
https://www.studiospares.com/Cables-...nit_450270.htm
What do u suggest? How should be the correct "flow"?
It will be for a "mobile' project so I need to have a PDU in the rack to take power for just one source, I think
DIY Audio Alchemy Power Station 2 Power supply PSU with case roscoeiii Swap Meet 2 29th May 2010 07:51 PM
TA8259H Max Power 37W BTLx4CH audio power IC for sale winkison Swap Meet 0 10th July 2008 10:42 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
power output calculations, rated power and required power output metebalci Tubes / Valves 7 22nd February 2004 06:49 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
