How to use this transformer with tube rectification - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 13th October 2014, 09:02 PM   #1
JBLman is offline JBLman  United States
Talking How to use this transformer with tube rectification
I have an r core transformer laying around and have good luck using it with a full wave bridge. But now I'm looking into replacing the bridge with a tube rectifier (274b) here's a link to the transformer:
https://tubedepot.com/products/r-cor...er-transformer
I know I need a ct on sec. #1 and sec. #2 is there a way for me to add it into the circuit?
Any help would be great as I don't want to use the Hammond or a toroidal transformers.
Old 13th October 2014, 09:17 PM   #2
rayma is offline rayma  United States
You do need a center tap for using two rectifiers per secondary. Without a center tap, you can use a full wave bridge by adding two more rectifier tubes.
The usual dual rectifier tubes have a common cathode, so you need two more separate tubes to connect their anodes instead of their cathodes for the second pair.
The filament winding normally uses silicon diodes, though.
http://www.hammondmfg.com/pdf/5c007.pdf
Old 13th October 2014, 09:42 PM   #3
Isn't there a way to just make the center tap? Without all the extra hardware ( more tubes and diodes)?
Old 13th October 2014, 10:14 PM   #4
kevinkr's Avatar
No, the simplest way would be to implement a bridge using a pair of silicon diodes (UF4007) for example and your 274 rectifier tube. Google hybrid graetz bridge for more details.
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 14th October 2014, 12:13 AM   #5
Yes, and this will still give you a soft start.
Old 14th October 2014, 01:20 AM   #6
AJT is offline AJT  Philippines
AJT's Avatar
the traffo you are eyeing has secondaries not suitable for your requirement...https://d1sjrnpi226dnf.cloudfront.ne...pdf?1382030398
while it is possible to use secondary #2,it is rated for 3A and the 274 needs just 2A, you will have to use a dropping resistor,about 1ohm/10 watts.... center tap is not possible...although you can put two 56 ohm resistors on either side of the filaments to mimic a center tap...
the best advertisement for a good audio design is the number of diy'ers wanting to build it after all the years....never the say so of so called gurus....
Old 16th October 2014, 02:17 PM   #7
Thanks guys for the help! Much appreciated! I did just stepperated the filament with a small 5v 2a ct transformer solved all the problems.
Old 21st October 2014, 06:27 AM   #8
Default zcvb
very nice posttttttttttt
______
shafiq
Old 21st October 2014, 07:10 PM   #9
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Avoid that transformer like the plague.
It was designed for 100V mains, you have nominal 120V which often reaches 127V
Normal design expects and stands +/- 10% ... which would mean 110V tops ... you can easily have 27% more.
Overvoltage beyond a certain point (which you will surpass) dramatically increases core saturation and loss, there's many threads on that.
It's irresponsible for Tube Depot to sell them and shrug off "you can use them with no problems"
Even the 6.3V filament voltage is wrong by a lot ... 7.6 V AC .
Don't be blinded by the apparent low cost.
Old 21st October 2014, 11:57 PM   #10
AJT's Avatar
it is possible that when the traffo is loaded, that voltage can drop to 6.5v or so...
Hybrid rectification tube/diode gmant123 Power Supplies 3 4th January 2013 09:51 PM
Tube vs. Semiconducter rectification Richard Ellis Tubes / Valves 44 14th August 2008 05:20 AM
solid state Vs Tube Rectification sandy Tubes / Valves 3 3rd September 2004 05:20 AM
Dual rectification off single sencondary transformer question Super_BQ Tubes / Valves 7 25th July 2004 03:44 AM
Help needed on tube rectification. w00t Tubes / Valves 10 10th March 2004 03:14 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
