Secondaries not to be used independently - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 6th October 2014, 08:43 PM   #1
Default Secondaries not to be used independently
I'm looking at some dual secondary transformers for a DAC project (I need 6x 6VAC transformers), but most of the ones in the size range I need say that the secondaries are intended to be used in series or parallel, not independently. Does anyone know why and what will happen if I do?
Tyler
Old 6th October 2014, 08:49 PM   #2
jcx is offline jcx  United States
likely just that the insulation sec-sec isn't rated for any more V than seen in series operation
probably OK to use in floating sec/dual bridge type dual supply with common gnd on the bridges
but would exclude using for say separately isolated heater supplies in a DHT tube amp with 100s of V between secondaries
Old 6th October 2014, 09:19 PM   #3
kevinkr's Avatar
It likely means they are wound on top of each other with no insulation beyond that on the wires to provide winding isolation.
In some applications where the windings are operating at different potentials the lack of additional insulation may be a problem.
I've not yet run into a transformer with this specific warning, although I have seen warnings to not parallel multiple transformers of a given type due to potential mismatches transformer to transformer.
What is the intended application?
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 6th October 2014, 09:20 PM   #4
It could mean a lot of things, why do you need 6 floating supplies ?
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 6th October 2014, 09:30 PM   #5
A strange warning. And vague to the point of being unhelpful.
I would take it to be saying not to use these windings to buck or boost the primary windings.
If your application has the windings at notionally the same potential, then I would just use it.
Old 6th October 2014, 10:40 PM   #6
This is one of the trafos I'm looking at:
https://system.netsuite.com/core/med...8ad2a&_xt=.pdf
They'll be used with bridge rectifiers and common grounds. The DAC setup has inputs for a separate transformer secondary for every power supply on the board, of which there are a lot (6x total of 3.3V and +/-5V supplies, one -15V).
Tyler
Old 6th October 2014, 10:54 PM   #7
Vasquo is offline Vasquo  United States
I think it just means that don't expect 25VA rating if you'll be using only one set of the primary or secondary windings. The 25VA is for the secondaries connected in series, or parallel.
Same goes for the primary winding... connect them either in series (for 220V operation) or parallel (for 110V) to get the 25VA rating.
Old 6th October 2014, 11:00 PM   #8
That's fair enough, I think even 25VA is overkill in this application, though I'll have to check.
Tyler
Old 7th October 2014, 01:42 AM   #9
could be wound bifilar so only wire insulation between windings
Old 7th October 2014, 01:56 AM   #10
rayma is online now rayma  United States
Yes, all this means is that the two secondaries must be connected in series or parallel, not floated at significant voltages apart from each other.
Transformer with 3 secondaries bondul Analog Line Level 5 11th May 2014 09:58 AM
unused secondaries freeman Power Supplies 10 30th March 2014 02:07 PM
One transformer with 4 secondaries or two transformers with dual secondaries Baka Chip Amps 5 28th November 2008 06:39 AM
Distribution Amp - How to switch off buffers independently? markolexus Solid State 0 5th October 2008 02:21 PM
Parallel secondaries barendh Parts 14 15th April 2007 02:13 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
