Help me solve my buzz, please!
Old 14th September 2014, 06:49 PM   #1
Deafuser is offline Deafuser
Default Help me solve my buzz, please!
Hi, I have a Raspberry Pi with Open Elec installed, which seems to make me a happy media player. So I after being happy with my install, decide to build me a linear supply! Acquired a transformer v-0v-v and with a couple of 5 volt regulators I have built a supply using 1 rail plus centre tap of the transformer and created a supply. I did originally parallel the 2 yellow wires on the transformer to double the current, black being 0 volts, but the transformer started cooking, oops! So I just used one wire and the 0v tap and I got 5 volts for the Pi! Well getting carried away, I built another 5 volt supply for my USB DAC! Great I thought, eager I wired it up, BUZZZZZZZ! It only goes away, if, I unplug the feed to the Pi! I used star earth, and just realised I don't have any caps across the 5 volt rails after the Regs, only before! Would having no caps after cause the buzz, or is it because I'm sharing the Centre Tap!
Thanks, Mike
Old 14th September 2014, 07:50 PM   #2
Default Attached
My psu, added caps after regulator, still buzzing!!
Old 14th September 2014, 08:07 PM   #3
payloadde is offline payloadde  Europe
payloadde's Avatar
You need to have a common ground for both outputs.
You don't and thats the problem.
Normally the center tap is the ground and this is how I would do it.
Judge: This court appreciates that you invented physics, Mr.Newton, but unfortunately you can't have a patent on it.
Old 14th September 2014, 08:16 PM   #4
Hi payloadde, thanks for replying. Why no Bridge rectifier?
Old 14th September 2014, 08:25 PM   #5
Default Point a
Is the output of the lower diode connected to the upper diode? If so, why 2 reg's? Thanks
Old 14th September 2014, 08:32 PM   #6
payloadde's Avatar
With CT xfmr 2 diodes make a perfect full-wave rectifier, no need for a bridge.
The two yellow ends of a CT xfrmr are of opposite phase with respect to the CT, so either the upper or the lower diode conducts.
Center tap - Wikipedia, the free encyclopedia
If you don't have 2 separate diodes at hand, it can be done with a bridge, but only one half of it will be active.
Old 14th September 2014, 08:44 PM   #7
payloadde's Avatar
I thought you needed 2 regs because of power consumption and because you wanted to separate the two outputs so that noise / power spikes from one device would not affect the other ... if that's not your concern, just use one, but if you already have them, why not use them.
Old 14th September 2014, 08:50 PM   #8
payloadde's Avatar
and that's also the reason why your xfmr cooks when you connect the 2 yellows, thats equivalent to a short.
Old 14th September 2014, 09:39 PM   #9
Default Thanks payloadde
Many thanks for helping, will rebuild and post back with results, soon! Thanks again.
Mike
Help me solve my buzz, please!Hide this!Advertise here!
Please help me solve the problem MlinarS Tubes / Valves 16 6th July 2016 04:13 PM
Buzz/Hum from Audiosector LM3876 board itself - no buzz in speakers dakku Chip Amps 4 12th April 2014 02:51 PM
buzz buzz... probleme with VSPS 6ri.l Analogue Source 0 19th August 2010 04:41 PM
Can Someone solve my buzz/Hum noise from turntable FSHZ42 Everything Else 3 23rd March 2008 10:51 AM
Melos triode and computer as source: BUZZ BUZZ BUZZ zigo3 Tubes / Valves 4 28th November 2007 02:11 AM
Copyright ©1999-2017 diyAudio
