I have a 24v switching psu that for some reason when hooked up to an amp makes the sound like a distorted mess like a wireless connection dropping in and out at the same time. It reads that it outputting 24v ; when i pull the plug out the music sounds normal for a couple of seconds before the power dissipates.
It did work properly for a while, and i have tested the amp with another psu and it's fine so definitely the psu.
Any ideas would be appreciated..
Bad output cap or rectifier?
most likely, thanks for that - not much i can do about it but get a new one..
Pulling too much current from the smps?
Could be.
It could also be the opposite, not pulling enough and so the SMPS enters a burst mode.
- Power Supplies
- Strange PSU
