Dual Voltage power supply ??
Old 1st September 2014, 01:41 PM   #11
DF96 is offline DF96  England
Why use silver solder? As you have discovered, it is harder to make a good joint. In electronic soldering the quality of the joint is far far more important than which alloy is used.
Old 1st September 2014, 02:20 PM   #12
bobrown14 is offline bobrown14  United States
The silver content 2-4% doesn't make the joint harder to make. Eutectic silver solder melts like butter and gets a nice silver finish to it so you know your joint is perfect. I do not and have never had any issues with silver solder and prefer it over tin/lead or lead free, not even close comparison IMHO. I do a fair amount of soldering.. probably every day or almost every day for several years.
Bob
Old 1st September 2014, 02:39 PM   #13
Originally Posted by bobrown14
I got it - pulled a leg on each diode to double check and after re-soldering them to the board I've got balanced voltage!! Light board still not working properly tho.... more cold solder joints probable......I couldn't tell even under VERY close look I couldn't see the bad solder joint, I was looking I swear!
So using silver solder has the advantage that an experienced solderer using the right equipment can produce bad joints which look exactly like perfect joints?
Old 1st September 2014, 02:52 PM   #14
The cold solder joint was there from the factory original work NOT my work. My soldering FIXED the cold solder joint NOT the other way round there. Thanks tho for helping me.
Bob
Old 1st September 2014, 02:54 PM   #15
Sorry, I misunderstood.
Dual Voltage power supply ??Hide this!Advertise here!
Dual voltage power supply michouthefirst Equipment & Tools 6 14th November 2012 12:54 AM
Using two positive voltage regulators for a dual polarity power supply dragosmze Power Supplies 7 8th October 2012 05:59 PM
Wanted: variable voltage dual output dc power supply giantslalom Vendor's Bazaar 0 9th September 2011 06:18 PM
high-voltage regulated dual power supply zzz Solid State 1 17th September 2002 01:15 AM
