Reflektor-D builds
Reflektor-D builds
Old 1st September 2014, 02:46 PM   #81
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Reflektor-D builds
Only for the initial test, unless the test feed comes from a bench supply that you can set a current limit. Though you can still fuse the incoming DC line for extra peace of mind during service life. But the transformer primary is necessary to fuse. What about the temps at such high current level that you use? On board sinks holding enough? Mike sent you the 5cm tall ones, right?
Old 1st September 2014, 02:50 PM   #82
merlin el mago is offline merlin el mago
merlin el mago's Avatar
The heat sinks are from my stash, isn't any problem of temps, I touched the heat sinks and isn't extra hot.
Old 1st September 2014, 02:52 PM   #83
Salas's Avatar
Reflektor-D builds
How tall are your sinks?
Old 1st September 2014, 02:53 PM   #84
5cm.
Old 1st September 2014, 02:56 PM   #85
Salas's Avatar
Reflektor-D builds
OK, all departments doing well.
Old 1st September 2014, 02:57 PM   #86
Thanks for your interest.
Old 3rd September 2014, 04:51 AM   #87
nezbleu is offline nezbleu  Canada
nezbleu's Avatar
Reflektor-D builds
I ordered these boards with no particular plan in mind, I really just wanted a pair to stash away for a rainy day. However, I think I just bought a Logitech Squeezebox Duet, so I may have a winter project looming.
Old 4th September 2014, 04:38 AM   #88
didiet78 is offline didiet78  Indonesia
Salas, have you comparing Subbu DAC V3 with original PSU (JP PSU) with Reflector-D ?
Didiet
Usb I2S + AK4490 / WM8805+ESS9023 / SDHC Card I2S audio player + AD1860
Old 4th September 2014, 01:46 PM   #89
Salas's Avatar
Reflektor-D builds
No
Old 5th September 2014, 03:29 PM   #90
randytsuch is offline randytsuch
So I am considering using a reflektor to power an oscillator.
Can the reflektor provide about 2VDC? The oscillator will run down to 1.7V, and I can go up to 2V, maybe a little higher but would prefer not to go over 2.
TIA
Randy
My system is here
http://randytsuch-audio.blogspot.com/2005/10/my-system.html
Reflektor-D buildsHide this!Advertise here!
GB for Salas Reflektor-D Power Supply for Digital Tea-Bag Group Buys 365 5th July 2017 02:40 PM
NOS Russian Reflektor 6P6S (6V6) tubes were a pleasant surprise KrankKall Tubes / Valves 7 26th February 2014 08:07 PM
Some VX.2 Builds CSS/XBL CSS 0 11th April 2013 06:34 PM
FS 8X 6P3S Reflektor Valves NOS Tbird Swap Meet 9 6th June 2011 04:18 PM
so who here builds amps amp builder jb Tubes / Valves 29 15th July 2005 09:23 PM
Copyright ©1999-2017 diyAudio
