Reflektor-D builds
Reflektor-D builds
Old 28th August 2014, 10:36 PM   #21
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Thank you. Yes Mike sent me 2 green + 2 reds + 2 yellows. How much voltage is the diode?
Old 28th August 2014, 10:41 PM   #22
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Reflektor-D builds
At that low current maybe 0.5-0.6V but depends on sample. Use the Atlas.
Old 28th August 2014, 10:48 PM   #23
Diode 0.68V
Red LED 1.78V
Red LED 1.76V
Residual 1.22V
Total 5.44V
Green & yellow LEDs have more voltage.
Old 28th August 2014, 11:14 PM   #24
Salas's Avatar
Reflektor-D builds
Diode test at how many mA?
Old 28th August 2014, 11:36 PM   #25
Salas's Avatar
Reflektor-D builds
Try on the reg, it will run a lower total.
Old 29th August 2014, 08:56 AM   #26
I don't know, measured with the Atlas.
Old 29th August 2014, 08:56 AM   #27
OK I will try.
Diode 0.68V
Red LED 1.78V
Red LED 1.76V
Residual 1.22V
Total 5.44V
Old 29th August 2014, 09:01 AM   #28
Salas's Avatar
Reflektor-D builds
The model 55? It scrolls and mentions current if I remember correctly. Maybe 5mA.
At 2mA those reds were 1.735V. You got to test with dummy on the reg, wait to go hot and measure. Just solder lightly on top edge of the pad before finalizing choices. You don't have to use diode only, you can use resistor also. 0.02V for 10 Ohm, 0.2V for 100 Ohm etc.
Old 29th August 2014, 09:04 AM   #29
Yes is the Atlas DCA55, one LED 3.54mA the other 3.52mA
Old 29th August 2014, 09:12 AM   #30
Salas's Avatar
Reflektor-D builds
Still more than in the reg. Look in the instructions there is a diagram with a resistor and a 9V battery for 2mA. Maybe two greens and a small resistor instead of diode will be the easiest in the end. Has to be 5.25V exactly, or there is allowance?
Reflektor-D buildsHide this!Advertise here!
GB for Salas Reflektor-D Power Supply for Digital Tea-Bag Group Buys 390 5th July 2018 12:52 PM
NOS Russian Reflektor 6P6S (6V6) tubes were a pleasant surprise KrankKall Tubes / Valves 7 26th February 2014 07:07 PM
Some VX.2 Builds CSS/XBL CSS 0 11th April 2013 05:34 PM
FS 8X 6P3S Reflektor Valves NOS Tbird Swap Meet 9 6th June 2011 03:18 PM
so who here builds amps amp builder jb Tubes / Valves 29 15th July 2005 08:23 PM
