Reflektor-D builds
Reflektor-D builds
Old 13th January 2018, 08:37 PM   #1341
sbelyo is offline sbelyo  United States
Originally Posted by AndrewT View Post
The best mode is locating the regulated PSU on top of the power input pins of the receiving circuit.
Then it makes no difference whether you use local, or remote sensing.
Interesting, I'll see if I can set that up
Old 13th January 2018, 10:40 PM   #1342
If I couldn't stack it, what is the maximum length of connection for two wire and four wire?
Old 14th January 2018, 02:42 AM   #1343
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Reflektor-D builds
The Mini version is small so to can go near. Uses classic two wire output. If you can use no more than 5cm of 12 AWG cable it will be very nice. Longer is not reactionary just more mΩ.
Four wire output in the big version has not a burden of output wires length vs added resistance but the inductance of the sense cables and the extra loop area they create must not allow for instability or interference problems. That should be monitored in any build that has different client circuit load, distance, wire dressing, and RFI presence, so there is no defined max length answer. Only guidelines.
Keep Kelvin four wire not longer than necessary, twist sense wiring well, and verify the rail stability with a scope.
Old 14th January 2018, 04:34 PM   #1344
Thanks, I think I can keep the connections at 5cm
Reflektor-D buildsHide this!Advertise here!
GB for Salas Reflektor-D Power Supply for Digital Tea-Bag Group Buys 368 2nd December 2017 02:52 PM
NOS Russian Reflektor 6P6S (6V6) tubes were a pleasant surprise KrankKall Tubes / Valves 7 26th February 2014 08:07 PM
Some VX.2 Builds CSS/XBL CSS 0 11th April 2013 06:34 PM
FS 8X 6P3S Reflektor Valves NOS Tbird Swap Meet 9 6th June 2011 04:18 PM
so who here builds amps amp builder jb Tubes / Valves 29 15th July 2005 09:23 PM
