Reflektor-D builds
Reflektor-D builds
Old 28th December 2017, 06:59 AM   #1321
feverdiy is offline feverdiy  Hong Kong
Hi Salas,
I need two 1.2V for supply the DAM1021 CPU and bias the digital isolation transformer.
If I use one Reflektor-D at 5V output and connect to two LM317 (set both output to 1.25V).
Will Reflektor-D stable in this application ? and safe to do so (connecting the output to another 3pins regulator) ?
Thank you.
Old 28th December 2017, 05:45 PM   #1322
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Reflektor-D builds
Connecting REF-D's output to distributed chip regulators is stable as many already use it in such a master reg's role.
Prefer low noise modern LDO than 317 if you can. Like LT1963A in DCQ package which is easy to solder by hand despite surface mount.
Old 29th December 2017, 12:35 AM   #1323
Thank you for your advice.
Could you tell me the different between LT1963 and LT1963A ? Because I can get LT1963 easier than LT1963A.
Old 29th December 2017, 01:17 AM   #1324
Salas's Avatar
Reflektor-D builds
TL1963ADCQT type is stable to ceramic output capacitor. Made by Texas its cheap enough in that package. The TPS7A4501DCQR is its alternative.
Bypass ceramics of high coefficient dielectrics have unstable characteristics vs bias voltage and temperature. But this is a concern in industrial grade.
You will use 10uF electrolytics of no more than 3 Ohm ESR very close to its input and output pins. You have to read the datasheet carefully anyway.
There is also the more expensive LT1963ET from Analog Devices/LT which is TO-220 and adjustable but not that tolerant to high coefficient ceramics.
Fixed output 3pin variety LT1963s don't come in lower preset than 1.5V unfortunately and are SMD only.
Old 29th December 2017, 01:52 PM   #1325
wyan is offline wyan
Hi, Salas, just want to say thanks for the wonderful design.
I like it so much that I had to make a version to accommodate Mundorf 4-pin cap as C2 capacitor to filter LEDs.
Also, it is very useful to keep those socket pins. Voltage can be changed to desire any time. Cheers.
Old 29th December 2017, 02:55 PM   #1326
Salas's Avatar
Reflektor-D builds
Nice. What equipment does it power?
Old 29th December 2017, 02:58 PM   #1327
Hi, I am using three for DAM1121, two for DIYinHK USB to I2S board. And I shall use them to a ES9038Pro project. Just so easy to use and works so great! Thanks again.
Old 2nd January 2018, 02:17 PM   #1328
pistollero is online now pistollero  Portugal
Hello, is the quality of rx important as r6 for the 3.3v setting??
i going to use vishay var on r6 i donīt know if is need too for rx....
Old 2nd January 2018, 03:02 PM   #1329
Salas's Avatar
Reflektor-D builds
Rx's importance is marginal. Just use a good 50ppm - 100ppm 1/4W metal film.
Old 7th January 2018, 10:28 AM   #1330
Thanks Salas for you response.
can you explain me about the capacitors on reflektor-d...
for example i bought russian teflon 6800pf to use with r5 2.2ohm.
what do i need to measure or know about the specs for comparing it to the wima mkp10... or vishay 1837... how to i know they are better or not technically...
about the c2... i īve been reading some datasheets and i found values for ripple current and impedance at 100kh.. with increase of voltage the better the ripple current and impedance.. and what about esr?? should i measure the esr??
what are the important specs of the c2 to have in account when picking the c2 cap?
is the same aspects of c2 applied to cm?
best regards
Nuno
Reflektor-D buildsHide this!Advertise here!
GB for Salas Reflektor-D Power Supply for Digital Tea-Bag Group Buys 387 4th June 2018 08:51 PM
NOS Russian Reflektor 6P6S (6V6) tubes were a pleasant surprise KrankKall Tubes / Valves 7 26th February 2014 07:07 PM
Some VX.2 Builds CSS/XBL CSS 0 11th April 2013 05:34 PM
FS 8X 6P3S Reflektor Valves NOS Tbird Swap Meet 9 6th June 2011 03:18 PM
so who here builds amps amp builder jb Tubes / Valves 29 15th July 2005 08:23 PM
