Reflektor-D builds
Reflektor-D builds
Old 20th October 2017, 12:48 AM   #1281
alazira is offline alazira  United States
alazira's Avatar
Hi Salas,
What would be the effect of a small cap in this position?
Old 20th October 2017, 10:33 PM   #1282
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Reflektor-D builds
Some noise curve shaping at the few MHz territory I suppose since it forms an RC with the base stopper resistor.
Old 22nd October 2017, 05:49 AM   #1283
nautibuoy is offline nautibuoy  United Kingdom
nautibuoy's Avatar
I am using a Reflektor-D, built from a Tea-Bag supplied kit, to power my Twisted Pear Buffalo 3SE board.
I plan to upgrade the DAC to TP's new ESS9028 based Buffalo board but it demands more current from its power supply, specified as 750mA. In my build I will only need about 720mA (because I don't use the Buffalo's onboard oscillator) but this is still well beyond the Reflektor-D's capability. Is it possible to modify the Reflektor D to deliver this level of current?
Old 22nd October 2017, 06:28 AM   #1284
Salas's Avatar
Reflektor-D builds
The Ref-D's current ability is a matter of sinking mostly. The spec limit is for the certain on board sinks. Its a conservative current spec not a break down spec though. If you have the bare minimum Mini version for example, which is externally sinkable only, you can readily bolt it to larger sinking. If you got the full version with the onboard rectification and sinks you can either affix a mini fan on them as they sit close together forming a hollow square top, or remove them and extend the Mosfets pins to sink them externally.
A quality mini fan can be used with under-voltage to 2000-2800 rpm where it should be quiet. If you will need set for more than 850mA, especially when without forced cooling, better replace the the IRF9610 with a Fairchild FQP3P20-ND. Tad slower by gate input pF number but significantly cooler in its core per dissipated Watt. Then you can go over 1A even. As a rule of thumb don't allow much more than 55C on sinks for good long term reliability. If they don't suffice for that make them bigger or cool them.
Old 22nd October 2017, 11:00 AM   #1285
nautibuoy's Avatar
Originally Posted by Salas View Post
...replace the the IRF9610 with a Fairchild FQP3P20-ND...
Thanks Salas, I have the full sized Reflektor-Ds with onboard heatsinks.
So, if I keep the board as is except for swapping in the cooler-running Fairchild device and changing the current setting resistor (R1 = 0R8 will give about 760mA total current) it looks like I might be able to get 720mA the DAC would need - I don't have space for a fan or off-board mounted devices.
The Buffalo 3SE DAC board obviously has its own local Trident regulators following the Reflektor-D
Last edited by nautibuoy; 22nd October 2017 at 11:09 AM. Reason: more detail added
Old 22nd October 2017, 11:28 AM   #1286
Salas's Avatar
Reflektor-D builds
The dissipation of that Fairchild will be the same of that IRF. Because the voltage drop and the current in the circuit dictate that. Its just that the Fairchild will be safer on a pushed current and small sink situation because it has better θjc i.e. transfers heat from its core to its case mounted at the sink more efficiently than the IRF. Safer, but up to a point of course. For more on thermal design basics this is a good read: http://www.analog.com/media/en/train...als/MT-093.pdf
Old 22nd October 2017, 11:46 AM   #1287
nautibuoy's Avatar
Yes. of course!
Old 22nd October 2017, 11:48 AM   #1288
Dimdim is online now Dimdim  Greece
Reflektor-D builds
IMHO 760mA of CCS current is cutting it a bit too close if the Buffalo's actual current consumption is indeed 720mA.
http://www.dimdim.gr
Old 11th November 2017, 01:25 AM   #1289
AnthonyA is offline AnthonyA
Hi Salas,
Will solid core wire perform better?
What do you suggest I do to make bass perform better? It's slightly soft.
Old 11th November 2017, 08:55 AM   #1290
Salas's Avatar
Reflektor-D builds
Try the JFET mod first
Reflektor-D buildsHide this!Advertise here!
GB for Salas Reflektor-D Power Supply for Digital Tea-Bag Group Buys 388 Today 03:57 PM
NOS Russian Reflektor 6P6S (6V6) tubes were a pleasant surprise KrankKall Tubes / Valves 7 26th February 2014 07:07 PM
Some VX.2 Builds CSS/XBL CSS 0 11th April 2013 05:34 PM
FS 8X 6P3S Reflektor Valves NOS Tbird Swap Meet 9 6th June 2011 03:18 PM
so who here builds amps amp builder jb Tubes / Valves 29 15th July 2005 08:23 PM
