Slow charge - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 21st August 2014, 04:01 AM   #1
BigE is offline BigE  Canada
BigE's Avatar
Default Slow charge
Is there any interest in building a slow charge circuit for a capacitor bank?
I have a starting point schematic, of a simple 555 timer circuit that stays on once the timer has expired. The signal can be used to power a couple relays, say like on a slow charge circuit?
Old 21st August 2014, 04:34 AM   #2
KatieandDad's Avatar
It's been done many times before and is generally called a "soft start".
These don't normally need to be too complicated but generally either employ a thermistor or a series resistor bypassed by a relay after a short period of time.
Old 21st August 2014, 05:17 AM   #3
BigE's Avatar
Soft start is different from slow charge -- soft start takes very little time, while the slow charge takes a lot more time, which brings in different issues. I guess that the slow charge is really more about using thermistors for long time periods before switching them out as well as relay and transformer ratings.
AFAIK, the timer must allow the thermistor to cool to the point that inrush to the capacitor bank is still managed. Hence, a timer circuit is needed to enforce a delay in which the thermistors may cool down to operating temp.
AFAIK, this is 50% of initial resistance, which implies that a slow charge ought to be built around using thermistors in series, whose values at 50% of rated resistance will still act as inrush current limiters. Perhaps this is a bit conservative, but it guarantees a safe start every time.
Then the timer needs to be at least this cool down time. Larger cap banks on high biased amps would need more time to ensure that the relay contacts are not damaged when they are switched.
The above circuit can be easily built P2P -- no real PCB is necessary.
Old 21st August 2014, 05:24 AM   #4
If you charge the capacitor bank too slowly it will never charge as the load will be emptying it faster than you are charging it.
Old 21st August 2014, 06:14 AM   #5
dangus is offline dangus  Canada
A little microcontroller like the ATtiny13 wouldn't cost much more and could be a lot cleverer. Programmers for those are cheap to almost free (resistors and a parallel port).
Old 21st August 2014, 06:30 AM   #6
apnneto is offline apnneto  Brazil
time-delay-slowly-charge-capacitor-bank
Old 21st August 2014, 03:07 PM   #7
BigE's Avatar
Hi apnneto,
Thanks for the circuit! It solved a problem in the one I posted: The cap attached to pin 5 is needed for stability -- my circuit would not simulate above a 10V Vp. Included is the LTspice file with the fix.
KatieandDad,
yes, that is fundamentally why I abandoned the idea of using resistors to limit the inrush. That circuit needed the load to be switched out to allow the caps to charge, then the load was switched in later. It required a very large number of resistors to slowly charge two banks of caps, one per channel, each being 176000uF.
IMO, the key element is to ensure that the timer that bypasses the thermistors is longer than the time that the thermistor takes to cool to 1/2 of the original resistance. Then you can use two in series, so that the design resistance is 1/2 the original resistance. There should be no problem filling the caps under load, as the series resistance is very low when the thermistors are hot.
Slow, slow, slow Frank Berry Forum Problems 18 15th October 2011 09:01 PM
how do i charge a capacitor? Infinity_Addict Car Audio 18 30th August 2010 09:26 AM
charge pump jamesrnz Solid State 1 13th August 2008 04:35 PM
charge pump jamesrnz Power Supplies 0 8th July 2008 01:23 AM
Copyright 1999-2017 diyAudio
