Simple 20 volt DC from 220 AC circuit - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 19th August 2014, 07:15 PM   #1
Sin Bin
Default Simple 20 volt DC from 220 AC circuit
Can anyone show me a VERY VERY BASIC idea /schematic ----on how to build
a simple bridge rectifier ---from a transformer 30 -0 30 ac out
--by very simple ---I mean no fancy IC ,S or complex circuits --
just a 20 DC from 30 V ac transformer --( 220 v AC in )
----do not want to include any lousy voltage regulator IC s that are not available
in the 3rd world --
just good ol diodes /capacitors please --
if impossible ---no problem !
will post a foto of the transformer ---was once used for a old TDA 140 watt guitar amp -- ( forgot the TDA #)
now I require 20 volt dc from it --
( printed on transformer as follows ) ---30 v --0 ----30 v---1.417 AMP
85 VA
nb ----no expert -- lotta hands on DIY experience---
prefer basic diagrams /sketches to complex un-fathomable-electronic jargon /theory
1.41 amps
Last edited by carl winter; 19th August 2014 at 07:31 PM. Reason: did not complete my question ! cut off !
Old 19th August 2014, 08:12 PM   #2
Elvee is offline Elvee  Belgium
Elvee's Avatar
in the 3rd world --
I am afraid it is going to be difficult: peak rectification, whether half or full wave will yield more than 40V, average filtering with a choke (not included in your initial BOM) will give out 27V or so under load, and half-wave plus inductor filtering half of that.
In any case, you' ll be seriously distant from your target voltage.
Completely avoiding active components would probably be possible in theory, using clever fractional voltage rectifiers, but honestly a cheap active circuit, not necessarily an IC will be much less costly and easier to source.
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 19th August 2014, 08:16 PM   #3
Regulated or unregulated?
Old 19th August 2014, 08:38 PM   #4
Sin Bin
those voltage regulators I have seen on hundreds of bridge rect circuits ---are moon rocks here --take months to order from US supplies
all I want is some brave fella to post a simple schematic that ie possibly retro 60 /s
transistors --- mostly diodes
but its DIY ---I hate ic/s they are nightmares to handle /solder on home made circuits---
--hens teeth
there must be a circuit somewhere that's novice /idiot proof?
why is a " voltage regulator"
so necessary ---?--no -don,t answer that ---the quantum theory is way beyond
us laymen ----
I simply build a circuit --I do not delve into mathematical hieroglyphics --way too
complex --
all I want is a schematic with few parts --that works (not in theory ) but finger blistering practical application
the amp (TDA 2040---I built works ok 23 VOLTS ( 2 x 12 volt bulky heavy batteries) ---not nice
--that's why the TRANSFORMER /rectifier circuit is needed--
or is there a commercially available plug in 20 volt dc from ac adaptor unit --
available ? I doubt its cheap or small -probably cost a fortune /take 3 months to
import ---
ok thanks for the help ---
will keep looking
Old 19th August 2014, 08:57 PM   #5
19V ex laptop power supply will do the job.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 19th August 2014, 09:08 PM   #6
WSJ is offline WSJ  United States
WSJ's Avatar
For 20 V out use a 21 V zener. R1=1k, Q1=Darlington. Use large heat sink for Q1.
Old 19th August 2014, 10:22 PM   #7
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
in the 3rd world --
85 VA
1.41 amps
What you say is impossible, standard voltage regulators are easily available even in the 5th World, go figure.
WHERE do you actually live?
Unless you live *here*, of course:
A 3 leg TO220 voltage regulator?
Old 20th August 2014, 09:33 AM   #8
Sin Bin
Default TO 220 voltage regulator
thanku for enlightening me - only 3 legs! WONDERFUL!-assumed a the V REGULATOR was a
MILLIPEDE legged nightmare ( never seen one )
SO it resembles a power transistor ? that's great news !
still --it takes 2- - 3 month wait for snail mail to central Africa
but now I can at least solder with ease --16 legged IC ,s are hell with
my eyesight at 65 ---thanku ---so much!
Old 20th August 2014, 09:49 AM   #9
Sin Bin
WSJ ---
you are the man ! ---exactly what I asked for --really appreciate!
a few questions ----
1 ------21 volt ZENER diode ----yes---( from old tv set)
2 -------Q1 = darlington pair transistors-?--or the 2N3055 power transistor? ( got a few from salvage of scrap)
as you have shown a 12volt DC bridge circuit --do I copy exact circuit shown?
or the same circuit using those above components?
I have the above 220volt ---12 volt AC transformer---
can you put all modifications in place on another schematic ----?
sorry ---gross amateur ---a bit lost here---
will scrap the 30 ac transformer---
rebuild the above circuit---
thanku so much ---really learnt another quantum leap!
Old 20th August 2014, 10:10 AM   #10
Sin Bin
Default pc laptop supply
WOW --- thanku SRETEN--- so simple --I was blind! damn thing is in front of me !
Brighton to the rescue ! --brilliant !
had no idea my old PC supply was 19 volt ! ( should always read the fine print---) even then I assumed it was milliamps -----
2 . I amp ---astounding---
now I can scrap nasty bulky 24 volt lead weights( 4kilos)
for a small compact /lightweight solution --
so very grateful --
but I do intend building that rectifier circuit WSJ has so kindly
posted for me ----you guys are superstars for ideas --
( my innate curiosity has forced me to learn the hard way --))
after all --- this forum is called DIY --- SO --
despite Mr Faheys sarcasm -----(--Tom Hank,s Pacific island is a lot closer to USA than I am )--he has no idea what corrupt incompetent
3rd world customs / mail system can do to one,s parcels/composure!
will figure out how the rectifier circuit works --in practise
much more challenge involved in hands on ---instead of
easy to plug in sealed mysteries---
thanku all ---regards
Help converting 13.5 volt ac to 20 volt majod Power Supplies 2 18th December 2013 05:41 AM
DC-AC converter circuit ThSpeakerDude88 Car Audio 33 13th September 2008 04:46 PM
AC to DC circuit switching using function generator, need help jegandren Power Supplies 11 6th August 2008 09:36 AM
AC to DC circuit design adeline Power Supplies 18 7th June 2007 03:27 PM
12 volt DC to 9 volt AC eRiCdWoNg Parts 10 18th April 2004 01:52 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright ©1999-2014 diyAudio
