Volt dividers after Power supply for different parts of the circuit ? - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 15th August 2014, 03:52 PM   #1
Ensoniq is offline Ensoniq  United States
Default Volt dividers after Power supply for different parts of the circuit ?
I certainly don't need a big toroidal transformer based power supply. But will need different secondary voltages for different parts of the circuit, amps will be around 14v, eq around 6v, fm radio 9v, etc. can I get away with using 14v adapter and making voltage dividers after rectifier bridge ?
Old 15th August 2014, 04:49 PM   #2
sofaspud's Avatar
Why not use 3-pin regulators? 9v from 14v, 6v from 9v, etc.
Circuit tolerances may also allow fewer separate voltages, e.g. can the eq run on 9v or the FM radio run on 6v?
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 15th August 2014, 04:56 PM   #3
Mooly's Avatar
I'd second the use of regulators.
Resistive dividers or simply a series resistor are poor on may fronts, not least efficiency. Any change in the current consumption of a circuit fed from such a feed will cause a change in the voltage. Not good.
Old 15th August 2014, 05:59 PM   #4
alright. regulators sound like a better idea. i'd have to do more research on them
Old 15th August 2014, 06:09 PM   #5
if i will be using bipolar power supply, i will need regulators both for negative and positive voltages?
Old 15th August 2014, 06:11 PM   #6
sofaspud's Avatar
Sure, why not. They're easy to use.
Old 15th August 2014, 06:37 PM   #7
Mooly's Avatar
They are very easy to use 78xx types for the positive rail and 79xx types for negative if they are available in the precise voltages you want. If not you can use a single zener diode to add to the voltage of the basic reg. For example a 5 volt reg and 3.3 volt zener would give 8.8 volts. The zener goes in the ground lead to the reg. Or there are adjustable regulators or you can add one transistor and one preset to a 78xx type and make a variable regulator.
Many many possibilities
12 volt power supply stoppage Power Supplies 19 27th September 2013 09:55 PM
Building power supply 9 volt from a Toroaidl transformer to dvd denon audio circuit dazzz Digital Source 41 17th September 2013 12:33 PM
9 volt overly complex(I think) power supply coolbeer Power Supplies 11 14th May 2010 07:54 AM
PARTS PARTS PARTS!!! Infocus Powerview 820, triplet, ballast, light, power supply!!! marioinla Swap Meet 1 31st August 2004 04:22 PM
Copyright 1999-2017 diyAudio
