SPST or DPST power switch? - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 16th August 2014, 07:40 PM   #11
jackinnj's Avatar
From the 2014 ARRL Handbook:
Old 16th August 2014, 07:46 PM   #12
Absolutely right. I am aware of two electricians that were killed because they thought they had switched off a circuit. A DPDT switch can short on the hot side and give the indication of being off when the circuit is still dangerous.
Old 17th August 2014, 01:02 PM   #13
jackinnj's Avatar
Might want to pass that along to the folks at Elektor and AudioXpress.
Old 17th August 2014, 02:50 PM   #14
DF96 is offline DF96  England
It may be that what the ARRL meant to say is that a switch/fuse should not be placed in the neutral line alone. Or maybe it can be guaranteed that no US installation ever has live and neutral swapped, or a fault which raises the potential of neutral?
Old 17th August 2014, 04:40 PM   #15
Speedskater's Avatar
Really it should mean an independent switch or fuse. A dual linked switch or circuit breaker would be OK. Don't think that we have any dual linked fuses handy.
Kevin
Old 18th August 2014, 02:03 AM   #16
My understanding is that this refers to breakers or fuses for the main house wiring, not for appliances, and, indeed, the code prohibits this.
Generator transfer panels must switch both hot and neutral, for obvious reasons.
I have seen numbers ranging from 0.5-2% for miswired home electrical circuits in the US. My personal experience—based upon the small sample size of every apartment I've lived or those for my friends—is that at least one miswired outlet is always present. My current apartment had 2 out of 11 outlets miswired, about 20%.
BUT, then again, my friends and I live in old buildings with antediluvian electrical systems because we're not rich, so YMMV. I'm sure newer buildings are wired better. Although when my parents had their kitchen renovated the electrical inspector did NOT check the wiring. It was all perfect, but that's not the point; the inspector simply did not check.
Old 18th August 2014, 08:15 AM   #17
Originally Posted by Retrovert View Post
................... My current apartment had 2 out of 11 outlets ....................I live in old buildings with antediluvian electrical systems ................
My Lounge has 8 double socket outlet plus 3 socket outlets for table lamps. Even the kitchen has 6 double socket outlets.
The whole 4bedroom house (~200m˛) has ~90 power sockets.
All have been checked during construction and rechecked by me using that simple and cheap plug in tester.
0% miswired.
And I still use double pole mains switching in my equipment, when switching is included. Some have an IEC inlet socket in lieu of a mains switch.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 18th August 2014, 01:13 PM   #18
jackinnj's Avatar
Anything pre-Tropical Storm Sandy is, by definition "antediluvian" -- at least south of 23rd St.
Old 19th August 2014, 08:42 AM   #19
Almeg69 is offline Almeg69  United Kingdom
As I run a balanced mains transformer, I will always use a double pole switch on my projects.
Thanks, Alex.
Old 19th August 2014, 10:01 AM   #20
freax's Avatar
Now... As a fan of Edison I'm using nothing but 12v/24v DC, so what is the story there?
The neutral of my battery bank is earthed so I could safely use SPST throughout however in the event of high voltage coming into contact with either my solar panel system/loads/battery bank I would need to leave Negative connected so the case of my projects don't become live. Correct?
The solar panel is supposed to be earthed. as part of Australian design code.
The battery bank must be earthed on the negative. as part of code.
There must be a breaker on the solar panels and on the battery bank from the load.
And all wiring must be run through "heavy duty conduit", i'm assuming that means metal conduit.
And of course signs setup for emergency personell's safety.
I may have to run a third earth wire for all loads? That way it shouldn't matter if I use SPST and disconnect positive only or use DPDT and disconnect both positive and negative at the same time.
If all else fails take the safest route. DPDT throughout with a dedicated earth wire.
Please note, I'm talking about a low voltage 12/24v DC system here.
As for fusing, I'm thinking of just fusing the positive side as usual.
diyaudio is against your rights. I do not have the right to be forgotten and after asking the issue has been ignored, therefore I'm leaving (peacefully) for this reason. I stand up for my rights. So long and thanks for all the Fish
circuit to switch LEDs and relays with an SPST tadakan Construction Tips 4 1st June 2012 06:46 PM
HELP - looking for round DPST or DPDT rocker switch CharlieLaub Parts 8 26th September 2011 03:34 AM
Help needed finding a small DPST switch - confused! Horsebox Tubes / Valves 15 30th March 2011 05:23 AM
Wiring SPST Switch with Neon Lamp PhrazeMaster Construction Tips 5 9th January 2011 08:28 PM
Quad SPST Analog Switch RCruz Solid State 7 25th November 2008 12:07 PM
Copyright ©1999-2017 diyAudio
