power supply regulator and EMI/RFI - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 5th August 2014, 06:52 PM   #1
clsidxxl's Avatar
Default power supply regulator and EMI/RFI
I have this power supply 1.0uV Ultralow noise DAC power supply regulator 3.3V 5.0V 800mA - DIYINHK to power the card clock Ian,then I put the power supply side of the card in the box,without affecting the clock card (and other)or it is advisable to place the power supply and the toroidal transformer together in an external case.
Old 8th August 2014, 06:42 AM   #2
Best to put the power supply's output pins as close to what it powers as possible, and keep the leads from the transformer as close to identical in length as possible.
Transformer placement is a never-ending debate, and I'm not in a useful position for that one .
Old 10th August 2014, 11:12 AM   #3
Looks like this might be a switching regulator.
All switching regulators emit interference.
This is often attenuated by enclosing the reg inside a sealed can that is secured to the chassis.
Then all the IN/OUT cables need interference filtering to complete the EMI/RFI compliance.
regards Andrew T.
Old 10th August 2014, 01:03 PM   #4
stormsonic's Avatar
ADM7150 is a low dropout linear regulator
Old 10th August 2014, 01:07 PM   #5
good.
regards Andrew T.
Old 11th August 2014, 07:31 PM   #6
clsidxxl's Avatar
The power supply is in the case of my dac next to the clock card,So, what do you recommend,I make a small box that covers the power supply,or it is not necessary.
EMI and RFI -- what you thought you knew jackinnj Solid State 2 11th December 2006 04:58 PM
Need Help with EMI/RFI Line Filter auric Parts 10 29th August 2006 04:35 PM
NOISE - RFI and EMI jackinnj Everything Else 9 26th February 2005 01:01 PM
RFI/EMI Shielding, is it necessary? mkruger Parts 1 22nd April 2004 05:54 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
