Enough current to turn on 3 mosfets?
Old 1st September 2014, 04:28 PM   #191
SGK is offline SGK
SGK's Avatar
R5/R12 - indeed seem redundant (I was thinking low pass filter but clearly all that's need is a short for DC)
C3 and C7 - guidance from datasheet is for R1 (R6) "greater than 2k, a pole will be created with [R1] and the amplifier's input capacitance, creating additional phase shift and reducing the phase margin. A small capacitor (20pF to 50pF) in parallel with [R1] will eliminate this problem." Will drop to 20pF - this helped (some is needed though).
This should reduce input offset. Does the datasheet guide you on this requirement? Is it needed?
I don't follow you here. Very new to op amps...
Will reduce it to 20x second stage.
Thx
Old 1st September 2014, 05:02 PM   #192
SGK is offline SGK
SGK's Avatar
Old 1st September 2014, 06:42 PM   #193
Mark Johnson is offline Mark Johnson  United States
I think if you make a rough, piecewise linear, sketch of the frequency response (a "Bode Plot") of that circuit, you'll probably get something like the attached. The three capacitors give rise to three poles and two zeroes (!), and that neglects the opamp's dominant pole. Ugh.
Maybe the circuit would be easier to analyze if C3 and C5 (figure below) were eliminated. Then the frequency response becomes drastically simpler: a single pole (due to C4). And then of course the opamp's dominant pole, which I cheerfully neglected when drawing this Bode Plot.
Speaking of the opamp's dominant pole, Walt Jung selected a GBW=63 MHz opamp (OP37) to build a gain=50 first stage. If you're going to use a GBW=7.2 MHz opamp (LT1677) to build a first stage, what sort of gain do you think is appropriate?
A final lagniappe to chew on: what is the output impedance of the circuit that drives this amplifier's input? What ratio of (Zin_amplifier / Zout_source) do you think is appropriate?
Old 1st September 2014, 07:53 PM   #194
SGK is offline SGK
SGK's Avatar
I was just reading about gain bandwidth product. I understand the quoted figure is the frequency at which gain falls to 1 and that "bandwidth" decreases as we add gain. Dropping the second stage to 20x already expands the upper 3dB point to 150kHz (gain 1st stage = 35x, 2nd stage = 20x). I don't have a reference point for what bandwidth is required and hence how much gain can be extracted from a pair of 7.2MHz unity gain bandwidth op amps. Obviously with a lower GBW device the figure will be a lot less but I need something to solve for and this I am lacking...
I need to think about your last point some more but presumably the circuit driving this one is the to-be-measured voltage rail with the output impedance I've previously modeled (for the 5V anyway) plus some wiring resistance. I understand that, in general, one wants a driving source to see an input impedance which is a good multiple of its output impedance. I need to think about the input impedance of this amplifier but the output impedance of the modeled 5V rail was only a few milli ohms in the high frequencies.
Old 1st September 2014, 08:33 PM   #195
Originally Posted by Mark Johnson View Post
... the very first stage should have extremely low noise and operate at high gain. That way, the noise of subsequent amplifying stages will be negligibly small -- it's effectively attenuated by the gain of the first stage. There is another benefit: RMS addition of uncorrelated noise sources diminishes the second stage's contribution even further.
The references below, particularly the blue-has-changed-to-purple one, flesh out the computations for this. Study the paragraph that includes
" noise voltages V1, V2 & V3 add to give a result of Click the image to open in full size.. ... Thus, if noise voltage V1 is more than 3 to 5 times V2 or V3, it is dominant, and V2 & V3 may generally be ignored, which simplifies noise assessment."
So a cascade of four amplifiers, each of whose gain is 5.63X **, has negligible noise contribution from stages 2-4. Similarly a cascade of three amplifiers, each of whose gain is 10.0X **, has negligible noise contribution from stages 2-3. You are free to trade gain for bandwidth and vice versa, as long as (1st stage gain x first stage ein) is > 5x (second stage ein). In the case where the first stage and second stage are built with identical opamps, ein1=ein2, making the math even simpler.
As for input impedance: Carefully note that noise-on-supply is produced by a circuit whose output impedance is the supply impedance ... i.e., far far less than 1 ohm. For the level of measurement precision you seek here, any amplifier input impedance greater than about 50 ohms will be more than adequate.
**_ Substitute the actual total gain requirement, instead of the phony-baloney placeholder "1000X" used here!
Last edited by Mark Johnson; 1st September 2014 at 08:33 PM. Reason: forgot attachment!
Old 2nd September 2014, 01:54 PM   #196
SGK is offline SGK
SGK's Avatar
Okey dokey. I see the attached trade-offs between gain/resolution and bandwidth. My scope goes down to a vertical resolution of 1mV per division and I have calculated the uV/div for each gain pair also. I still don't have a feel for what constitutes adequate bandwidth.
Regarding impedance, I just want to check one thing. You say "is the supply impedance". I thought the relevant output impedance is of the circuit providing the voltage being measured (12V, 5V or 3V3). (I recognise that in one of these cases it will be the same as the supply for the measurement circuit.) In any event, each of these circuits will have very low output impedances. Am I right to say the driving circuit will see a load of C4 in parallel with R4 which for all but very low frequencies looks like R4 i.e. 10k ohms. The relative impedance test is very easily met.
Old 2nd September 2014, 03:30 PM   #197
The output impedance of a 3.3V power supply is: that supply's impedance. Far far less than 1 ohm.
The output impedance of a 5V power supply is: that supply's impedance. Far far less than 1 ohm.
The output impedance of a 12V power supply is: that supply's impedance. Far far less than 1 ohm.
If you want your measurement apparatus to change the voltage being measured by less than X%, then the input impedance of your measurement apparatus needs to be
  • (Zin_apparatus / Zout_DUT) > [ (100% - X%) / X% ]
by straightforward circuit analysis.
Plugging in an example X = 0.639%, we find Zin_apparatus > Zout_DUT x 155. So if your 12V power supply's output impedance is 0.28 ohms, Zin_apparatus needs to exceed 43.5 ohms, in order to have less than an 0.639% effect upon the measured value.
You will probably want to tinker around with various possible values of Zout_DUT, and various choices of the permissible measurement error (X%), to see what kinds of impedance ratios (Zin_apparatus / Zout_DUT) you require.
Remember that you propose to "measure" noise by eyeballing the fuzz displayed on an oscilloscope. How precise do you think these "measurements" can be? Don't expect racehorse-quality results from a frog. Don't polish the wrong (excremental word).
The input impedance of your amplifier circuit can be extracted from simulation results, just as the output impedance of your power supply can be extracted. You simply apply an AC input current of 1.0 units, and measure the resulting AC voltage at the input. Ohms Law tells you that Vin = Iin x Zin, thus Zin = (Vin / Iin). You will find that when you ask LTSPICE to plot the ratio (V/I), it automatically displays the data using the units "Ohms". LTSPICE is aware of Ohm's Law. You will see that the input impedance varies with frequency, which should not be a surprise.
At extremely low frequencies, all capacitors are effectively open-circuits (ignoring DC leakage). At extremely high frequencies, all capacitors are effectively short-circuits (ignoring ESR). In between, capacitors smoothly vary between behaving as open-circuits and behaving as short-circuits. Thus circuit response varies with frequency. As your intuition predicts.
The Zin-versus-frequency plot will probably include a broad zone of frequencies where Zin is more or less constant. The magnitude of impedance in the center of this zone (called "the mid-band") is the number that people usually mean when they say "the input impedance is AAAA ohms".
Old 2nd September 2014, 03:53 PM   #198
SGK is offline SGK
SGK's Avatar
This I did earlier. It matched my expectation from just looking at the circuit schematic but I wanted to check this wasn't merely coincidental.
Unless I am missing something, the input impedance of the measurement amplifier (10k ohms) dwarfs the output impedance of each of the power supply rails (less than a few 10s of milliohms) by a massive margin. Job done - not a significant factor in measurement accuracy.
So I am just left with a bandwidth / amplification choice...
PS: gut instinct suggests 170kHz upper limit is more than enough but this conclusion is only drawn from observing charts on-line that tend to stop at 100kHz.
File Type: jpg Measurement amplifier input impedance.JPG (295.3 KB, 32 views)
Old 2nd September 2014, 04:31 PM   #199
The thing being powered is a box full of digital integrated circuits? Over what range of frequencies is it sensitive to power supply noise?
Presumably your new power supply is designed to produce especially low noise over that range of frequencies.
I assume one of your testing goals is to check whether the supply does indeed produce its design-target value of output noise, over that range of sensitive frequencies.
Old 2nd September 2014, 06:41 PM   #200
SGK is offline SGK
SGK's Avatar
That would be at the right way to approach the subject but I don't have answers to those questions. I started this project to put together the best power supply I could and learn a lot along the way. I'm certainly doing the latter with your great assistance. Perhaps I am chasing fool's gold on the former.
The addition of a measurement amplifier to the board came with two criterion (post 175): not too much cost in board real estate and not too much mental contortion. I'm likely reaching my limit on the latter. I suspect noise to far higher frequencies is of importance. However, I'm not sure that this configuration, constrained in part by a single supply and hence less gain bandwidth product at hand, provides a huge platform for choice. I could add another gain stage (7 or so extra components) but that sounds to me like "polishing a coprolite" to coin your phrase. If measurement at higher frequencies is required I suspect a separate amplifier module would be more appropriate. Lastly, I'm not sure what more, in practical terms, 270kHz covers that 170kHz doesn't.
Enough current to turn on 3 mosfets?Hide this!Advertise here!
Question about power supply excess turn-on current 90scaraudio Car Audio 2 2nd September 2012 09:07 PM
How much current to drive output MOSFETs? Ian Macmillan Pass Labs 17 28th October 2007 09:22 PM
Driving large mosfets: active PNP turn off Pierre Class D 31 15th August 2007 04:16 AM
hlpe ! Turn on get big current titanchen68 Class D 113 27th March 2006 10:56 AM
P3A turn on current surge Fritz Solid State 3 8th April 2003 10:23 PM
