+/- 8V TO +/- 5V - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 1st June 2014, 11:02 AM   #1
kinku is offline kinku  United States
Default +/- 8V TO +/- 5V
I am planning on using a Salas shunt regulator board for a DAC project which uses 8 and 5 dual voltage for different components . Other than using two dual voltage Salas Reg boards what are the options which will keep the low noise benefits of Salas shunt regs?
Float charger? Cut off at 13.5v rest until 12.5v before switch on? danielwritesbac Power Supplies 106 7th October 2012 11:03 PM
5v to 2.5v for 2a3 filament gasser-dude Tubes / Valves 7 13th February 2010 09:18 AM
Changing 1543 DAC from 8V to 5V. Help needed Nielsio Digital Source 5 1st January 2009 09:01 AM
8V on outputs dome406 Chip Amps 3 11th September 2005 03:16 PM
Can you make 0-5V DC out of 2.5-0-2.5V AC Ralph Tubes / Valves 17 23rd September 2003 03:20 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
