Simple power supply for 12Ax7 buffer tube. - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 28th May 2014, 08:26 AM   #1
hschaser's Avatar
Default Simple power supply for 12Ax7 buffer tube.
Hi all,
Need your expert advise on building a power supply for a single 12au7 tube to function as a stereo buffer.
Would appreciates if can advise with schematics and component values.
Thanks..
Old 28th May 2014, 09:07 AM   #2
SY's Avatar
Three necessary questions:
What do you mean specifically by "buffer"? That's a standard engineering term which has become ill-defined by EBay.
12AU7 or 12AX7 (you used both numbers and they are VERY different tubes)?
Schematic?
"Cities are globs. Globs are bubbling collections. Bubbling collections are hurricanes of the dead and the living all blasting subliminal stories lost in the nether of breezes."
Old 28th May 2014, 11:54 AM   #3
hschaser's Avatar
Hi SY,
Thank you for your prompt reply.
"Buffer" meant signal from source i.e CD player into a preamp circuit with a 12AU7 tube.
Intention is to get a "Tube like" sound after amplification via a class "t" amp.
Please forgive me of my ignorance..
Any help with the PSU would be most appreciated.
Thank you.
Old 28th May 2014, 12:04 PM   #4
SY's Avatar
Gain? Topology? This is important stuff to know before you sit down to design an appropriate supply.
By "tube sound," what do you mean? It's a very vague term that seems to mean different things to different people.
Old 28th May 2014, 12:20 PM   #5
hschaser's Avatar
Dear SY,
Thank you for challenging me in my approach.
I will research more and post in here ASAP.
I do not really need alot of Gain.
"tube sound" meant sounding nearer to an actual tube amp rather than a Class "T" amplifier.
Hopefully SRPP or Mu follower can give me a more tube sounding output.
Thanks once again..
Old 28th May 2014, 07:22 PM   #6
doctormord's Avatar
Ich wrote something related here:
wich is more suitible for a class D amp
90V were done via MAX1771 boost-converter.
http://www.360customs.de
Old 28th May 2014, 08:31 PM   #7
nigelwright7557's Avatar
Originally Posted by hschaser View Post
Dear SY,
Thanks once again..
You are unlikely to get the "tube" sound with one tube.
The "tube" sound usually comes from an amp as a whole including output transformer.
I have built solid state amps with front end SRPP and it still sounded solid state.
You might get somewhere near if you can cause the tube stage to distort a bit to get a warmer sound.
PCBCAD51 pcb design software. http://murtonpikesystems.azurewebsites.net/
Old 28th May 2014, 08:51 PM   #8
DF96 is offline DF96  England
Perhaps a 12AU7 cathode follower running from a +12V supply rail would generate sufficient distortion for nice 'tube sound'?
Old 29th January 2015, 08:15 AM   #9
hschaser's Avatar
Default inverted signal
Hi all,
i had completed a 12VDC powered 12AU7 preamp.
when I feed in a 1 K sine wave on the output end i get an inverted sine wave.(on my scope) Can any one pls advise is it normal or i had made a mistake in my circuit?
Attach is the circuit.
Old 29th January 2015, 08:24 AM   #10
hschaser's Avatar
https://dl.dropboxusercontent.com/u/...C%20preamp.jpg
Simple Variable Tube Power Supply Sal Brisindi Tubes / Valves 15 25th January 2012 06:51 AM
12v B+ Tube buffer 12AX7 benproiii Tubes / Valves 19 20th September 2010 12:49 PM
Tube Buffer? 12ax7? wttaylor Tubes / Valves 10 24th February 2010 01:40 AM
What Power Supply for 12AX7 Preamp ? chatziva Power Supplies 4 23rd December 2008 05:41 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
