Maida Regulator Digital Control - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 25th May 2014, 03:56 AM   #1
BRSHiFi is offline BRSHiFi  United States
Previously known as kingden
Default Maida Regulator Digital Control
What is the best digital potentiometer part that will work with high common mode voltages in a Maida circuit?
An idea I have is to place a digital pot in place of R1 in the voltage set circuit and have a high resistance resistor as R2 to drop most of the volts (and watts).
A problem I find with many of those parts is they do not seem able to withstand voltage on their wiper terminals relative to VCC, VSS, or ground. Also, current may be an issue as well.
If the digital pot idea will not work, what is the best control method? I suppose a discrete digital pot built with a resistor ladder and relays (or something) for switching will work. That will occupy much board space and will probably not be that accurate.
Maida Regulator PCB SpreadSpectrum Tubes / Valves 98 21st July 2012 07:25 AM
Maida regulator Andrewc556 Tubes / Valves 21 31st December 2010 03:29 AM
Maida regulator billr Tubes / Valves 15 23rd September 2007 03:19 PM
Maida's regulator mark_titano Tubes / Valves 3 29th January 2006 02:26 PM
Copyright 1999-2017 diyAudio
