Low noise symmetrical PSU TPS7A4701 and TPS7A3301
Old 22nd April 2014, 02:24 PM   #11
mravlca is offline mravlca  Slovenia
mravlca's Avatar
To make this "sense pin" useful, then it would be better to use two TPS7A4701. If using sense only on positive line and no sense pin on negative, then the circuit wouldn't have any benefit with it, as negative side would be, I expect, noisier.
BR,
Ales
p.s. Hopefully I will post new PCB this evening.
Old 23rd April 2014, 09:59 AM   #12
mravlca's Avatar
New circuit and new PCB. What do you think? I also had an idea to use rectifier bridge something like DBLS209G...
BR,
Ales
Old 23rd April 2014, 12:03 PM   #13
mravlca's Avatar
And a little bigger version, using SMD dip switch for configuring output voltage.
BR,
Ales
Old 24th April 2014, 03:44 PM   #14
mravlca's Avatar
Something like this maybe? Dimensions are 21.5mmx15.80mm, I could maybe squeeze it a little bit if using smaller solder jumpers.
BR,
Ales
Old 24th April 2014, 04:08 PM   #15
mravlca's Avatar
BR,
Ales
Something like this
Old 24th April 2014, 04:37 PM   #16
androa76 is offline androa76  Slovenia
Hello,
Second version of smal 3pin regulator is nice.
For big version i suggest complete regulator with diodes... make no sense half of big regulator to use. Dip switches is very good idea. Maybe do it so that can be brakable in more pieces if we use just one regulator. So AC input 4 smd schotky diodes big capacitor or even CRC and combination. Maybe at the output resistor diode combination for eye checkind that regulator is working and for empty the regulator if it is not connected to any load.
Odlično, sporoči kdaj bo izdelava in se priključujem nakupu, ker so doma v predalu TPS-ji neuporabni
l.p.
Old 24th April 2014, 06:39 PM   #17
Shelby is offline Shelby  Austria
Hi, you mentioned you will design this regulator for 3.3, 5 and 12V. This would be excellent to supply a PC. What are the max current capabilities of your design? Is it possible to have a 1,35V supply as well?
Old 25th April 2014, 09:26 AM   #18
mravlca's Avatar
regulator has programmable voltage output, so setting 3.3V 5V and 12V isn't a problem. Current capability is 1A. No, 1.35V isn't possible to have, but 1.4V is.
BR,
Ales
Old 25th April 2014, 04:12 PM   #19
mravlca's Avatar
Default Final version of 3pin regulator?
I believe this is the final version of 3pin regulator. Dimensions are 21.5mm*14.45mm, and this is really small. I added sense pins for + and -, this would improve quality of regulator, but if not needed they can be shorted with solder jumpers. (BTW I got hint via PM for sense pins). Through the weekend I will also try to complete PCB for dual voltage, and in the beginning of the next week, send gerbers for PCB production.
BR,
Ales
Old 27th April 2014, 03:32 AM   #20
rhythmsandy is offline rhythmsandy
can the input and output caps be tantalum KEMET make?
Generally its said Tantalums are better than ceramics or may be equivalent to ceramic
Invalid Request
Low noise symmetrical PSU TPS7A4701 and TPS7A3301Hide this!Advertise here!
Ultra-low Noise Valve Regulated PSU. How to? Kenneth Zhu Tubes / Valves 9 5th October 2010 07:18 PM
Low noise PSU for dacs on TNT guglielmope Digital Source 0 14th September 2008 08:28 PM
Low noise PSU for XO Clock Sunsun22 Power Supplies 7 16th April 2006 09:18 AM
Suggestion for the Low noise PSU for the osillator.... hatasa Digital Source 17 22nd November 2002 08:47 PM
