Go Back   Home > Forums > Amplifiers > Power Supplies
Old 30th March 2014, 12:50 AM   #1
ag8908 is offline ag8908  United States
Default Question about electrical shock
Strangest thing just happened. I was unplugging an amplifier's power chord from my power strip, and it was stuck. I had pulled the plug about one-half way out but it wouldn't come out any more. When I pulled on the plug, it would lift up the power strip, rather than unplugging. So I stuck my finger between the plug and the power strip to get a better grip, and accidentally touched the metal part of the plug, instantly sending a charge to my right arm.
I quickly let go.
Now here's the funny part. It didn't feel that strong really. I'm not sure I would even characterize it as a shock, it was more of an electrical vibration. I felt like I could have tolerated a few more seconds of that, maybe more. Is that what a 120v shock feels like? Or was the power strip putting out a weak amount of power or something? Or, perhaps, I have electrical super powers that I just discovered this evening?
Just out of curiosity.
Old 30th March 2014, 01:03 AM   #2
DUG is online now DUG  Canada
Some people use their fingers to test what the voltage is...other people die.
I don't really want to find out which type I am.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 30th March 2014, 01:04 AM   #3
Really? What's the biological difference in such people?
Edit: Actually I see in this link that it takes 2000v, pumped for many many seconds, to kill a person in an electric chair so I'm guessing 120v is tolerable for a second for most people (but don't try it).
http://hypertextbook.com/facts/NancyRyan.shtml
Old 30th March 2014, 01:16 AM   #4
jackinnj's Avatar
If you can't let go, you die.
My brother-in-law's neighbor was a Scot import who worked as an engineer for Con Ed in Queens NY. He could sense voltage just by getting his finger near it.
Old 30th March 2014, 01:19 AM   #5
Without even touching it? That's fascinating. How high of a voltage? I'm guessing professional power line stuff.
Old 30th March 2014, 01:26 AM   #6
120v is the RMS value, the peak value is higher.
see: Electric shock - Wikipedia, the free encyclopedia
Cheers / Chris
Old 30th March 2014, 06:55 AM   #7
If a part of your body is grounded, you'll get a much bigger shock. Whether it is fatal depends partly on where the current flows through your body. If your hands are wet (especially with perspiration), you will get a bigger shock.
120 volts can definitely be fatal.
I got hit by lightening and didn't die, but I wouldn't recommend it. I was bruised and burned and didn't feel very good, but I was OK the next day (except for a little deafness). I did need new shoes and jeans.
I would like to point out that the voltages inside many amplifiers can be dangerous. I'm working on an amplifier that has a 122 volt split supply. I guarantee that you could get a nasty shock from that.
Old 30th March 2014, 07:13 AM   #8
KatieandDad's Avatar
If there is no current path you wont feel a shock.
If there is a good current path you will feel a severe shock.
And all variations in between.
UK plugs now all have half shrouded pins to stop this happening.
Old 30th March 2014, 10:18 AM   #9
laplace is offline laplace  Australia
It was probably going through your fingernail and shoes which are both kind of high impedance, which means the current was small.
However if you felt the shock, you must go see a doctor. Even tiny (2mA) shocks through the heart can cause interesting arrhythmias that you will not be able to detect yourself but might put you in danger over the next few days/weeks. Get yourself on a ECG and make sure there is nothing damaged.
Open-Source F/Stop Timer
on flickr
Old 30th March 2014, 11:40 AM   #10
I quickly let go.
That's why the UK changed the specification of the BS1363 plug tops.
The older had pins that were unshrouded along their whole length.
The new standard specifies that the Live and Neutral pins are shrouded along part of their length so that a tiny finger inserted into the gap will only contact a disconnected pin
But most of the world think the UK is over protectionist.
regards Andrew T.
electrical question NED 209 Car Audio 19 5th October 2012 05:59 AM
Capacitor gives shock during charging gmphadte Solid State 7 22nd May 2011 08:49 PM
shock with hexfred's durkla18 Solid State 3 17th May 2008 07:20 AM
Shock vs. Electrocution TomWaits Everything Else 28 26th September 2006 10:42 AM
Electrical Transistor question??? sbisdabomb Parts 3 7th April 2005 05:51 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
