Breaking my head over AC+DC heater reference - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 16th March 2014, 02:38 PM   #1
funk1980's Avatar
Default Breaking my head over AC+DC heater reference
Can this be done:
I have a transformer with just one 12.6V winding. I really want the first stage's heater supply to be DC (6.3V) for noise reasons. The second stage (2x ECC99 PP) draws so much current that regulating is impractical and AC is fine there anyway. Is it possible to properly use one winding for both regulated DC and AC?? How about ground reference. Charging peaks etc.
Old 16th March 2014, 02:59 PM   #2
infinia is offline infinia  United States
infinia's Avatar
how much current you want on the 6.3V filament?
LM317 constant current source from rectified and filtered 12.6
all floating, may be a problem if the 1st stage is a rectifier at B+
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 16th March 2014, 04:21 PM   #3
funk1980's Avatar
Reading black my own post, I probably should have mentioned that the transformer only has one heater winding. There's one for B+ as well.
I need 6.3V @ 300mA DC and 12.6V @ 800mA AC from the same winding.
Old 16th March 2014, 04:36 PM   #4
infinia's Avatar
rectify 12.6 either full or half wave and run a LM317 and 4.7 ohm to set a constant 270 mA into the 6.3 filament, heat sink on LM317.
Old 16th March 2014, 04:39 PM   #5
KatieandDad's Avatar
A linear regulator would indeed waste a lot of the available power.
Why not try a buck regulator which would be much more efficient.
Old 16th March 2014, 04:44 PM   #6
infinia's Avatar
yes tubes waste a lot of heat too ,
I'd imagine trying save power, little here and there isn't their priority esp if quiet DC filament power.
Old 16th March 2014, 05:01 PM   #7
funk1980's Avatar
Yes, that's what I did. And I tied the DC 0V line to the GND of the rest of the circuit for reference. But I'm getting a lot of 50Hz interference and suspect the culprit being the unbalanced AC heater wiring. The AC before the rectifier is no longer a nice sine wave and I don't see a way to balance/ reference it.
Buck SMPS is a bit out of my comfort zone at the moment
Old 16th March 2014, 05:07 PM   #8
infinia's Avatar
cant you float the whole filament string and run the LM317 straight from 12.6 using full wave and a tiny cap for lower distortion?
using half wave cuts one side of the sine trading distortion for a just a little power saving. so bad for balance. full wave use a very small filter cap and a little series R
Old 16th March 2014, 05:16 PM   #9
Elvee is offline Elvee  Belgium
Elvee's Avatar
Here is a "creative" solution: it is not too wasteful, it remains balanced, and all filaments share a common that may be grounded if desired.
I assume the 12.6V filaments F1, F2 have a CT.
F3 is the 6.3V 300mA filament. The current can be fine-tuned with R5.
R4 is a dummy load, required to rebalance the bridge formed by the two high current filament.
The dissipation is the same as in the low-power filament, which is still tolerable
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 16th March 2014, 05:46 PM   #10
DF96 is offline DF96  England
Difficult. You somehow have to stop rectifier hash, charging pulses etc. from the DC supply getting onto the AC supply for the ECC99 - because this noise will be worse than simple AC.
Does the 12.6V winding have a CT? If so, it can be done by producing a bipolar DC supply (e.g. +-8Vish after rectification and smoothing) with the CT grounded.
AC Heater reference to B+ toufu Tubes / Valves 14 4th February 2012 12:21 PM
dc and ac heater supply in Aikido Jaap Tubes / Valves 2 7th March 2010 08:08 PM
AC or grounded DC for heater? rouslan Tubes / Valves 1 18th August 2006 02:16 PM
heater voltage: why ac, and not dc? alex278 Tubes / Valves 18 7th October 2005 12:21 PM
AC or DC Heater? sauuuuuce Tubes / Valves 2 27th October 2004 12:57 PM
Copyright ©1999-2017 diyAudio
