Pi filters
Pi filters
Old 15th March 2014, 07:21 PM   #1
alibear is online now alibear  United Kingdom
alibear's Avatar
Default Pi filters
Hi all, I am building a supply for a class A amplifier, the bias current is 1.7A per channel at 42Volts. I am hoping to use a CRC Pi filter consisting of 47,000uF R and 47,000uF. per rail. I am thinking of using a 1ohm 25watt resistor, can anyone see a problem with this value, should I try lower or higher values. What are the drawbacks with using this type of filter. Will there be any degradation to sound quality if R is too high.
Thanks for your help.
Alan
Old 15th March 2014, 07:33 PM   #2
DF96 is offline DF96  England
Why 25W?
Large R means too much voltage drop. Small R means less smoothing.
Old 15th March 2014, 09:53 PM   #3
alibear's Avatar
Hi, 25watt because I have some metal case resistors that I can use .
I think I can aford to drop a volt or two.
But main query is : is a 1ohm resistor too large a value, will it be derogatory to power supply performance?
Alan
Old 15th March 2014, 10:08 PM   #4
R.I.P.
Depends on the nature / topology of your class A amplifier,
regarding maximum current demands on the power supply.
BTW a proper Pi filter is CLC, not CRC.
Higher R will reduce the voltage available, but TBH @ 1.7A
around 1R seems about right to be useful but not invasive.
rgds, sreten.
A 5W resistor will do the job, no point complicating it.
Old 15th March 2014, 10:39 PM   #5
Too large a value for what? Performance in what sense?
You need to decide which compromise of voltage drop vs. smoothing best fits your amplifier design. For example, if your amp has very poor PSRR then you need good smoothing and have to tolerate more voltage drop. If your amp has serious second-order distortion then you will have a varying supply current (despite being Class A) and so may need a smaller resistor and have to tolerate more hum.
Old 16th March 2014, 08:01 PM   #6
alibear's Avatar
Hi everyone, thanks for the informative answers. Another question regarding CRC or CLC filters: what is the result if the first C after the rectifier is much smaller than the C after the R or L. For example, first C 10,000uF , final C 47,000uF. What capacitance does the amplifier actually "see"
Alan
Old 16th March 2014, 09:10 PM   #7
That depends on the value of the series element. In most cases it will be large enough that the amplifier will 'see' the final capacitor for AC purposes, but will also see that it is fed from a resistance which is a combination of the actual series resistance and the effect of voltage droop on the first (reservoir) capacitor.
Old 16th March 2014, 09:34 PM   #8
LineSource is offline LineSource  United States
LineSource's Avatar
Give a man a fish and he eats for a day.
Give a man a GOOD CAD tool and he is too busy to eat for a day.
Duncan power supply designer PSUD2
PSUD2
For ~1.7amps load, 47Ku x 1ohm x 47Ku, 60Hz
42.48 - 42.84V at diode bridge
41.042 - 41.048 at load ripple ~ 6mv, power loss ~ 1.44V
A CLC always performs better than a CRC.
A CRC has "better than calculated" ripple reduction with Class A bias output stages.
I think a 1 ohm resistor is too high and will drop unnecessary voltage, as shown by the 6mv calculated ripple.
Old 16th March 2014, 09:39 PM   #9
Sonce is offline Sonce  Macedonia
Use C1=C2 for the lowest ripple.
Old 16th March 2014, 09:44 PM   #10
Agreed, but L must pass high current without saturation, so usually it is expensive.
Pi filtersHide this!Advertise here!
Inductive PSU, SMPS and PI filters stu.dio Power Supplies 0 11th March 2012 10:03 PM
Tractrix in 1*Pi and 2*Pi revintage Multi-Way 21 26th August 2011 09:37 PM
Pi filters for simple supplies 454Casull Power Supplies 2 17th October 2009 09:02 AM
PI filters Prune Tubes / Valves 3 26th September 2004 09:16 PM
Questions about Pi filters eeka chu Pass Labs 2 28th November 2003 06:51 PM
