TL431 High Voltage Regulator - How to get it thermally stable?
Old 15th March 2014, 03:48 PM   #31
jazzclassics is offline jazzclassics
Originally Posted by Elvee View Post
You need to fix the transistor's base potential.
Now, it still requires some compensation to work properly
hi Elvee, this is really help. thank you very much. will you be able to simulate the thetmal stability of the circuit? i think the zener can be replaced with a current source. do you think it will make it better?
Old 15th March 2014, 05:27 PM   #32
dmills is offline dmills  United Kingdom
A current source would make it worse not better as you want the base at a fixed voltage not one which tracks with the output (which would be positive feedback).
Stop messing about in spice and BUILD the damned thing, while I would add a cap across the zenner to lower the noise and another one to stabilise the loop, the basic idea will work and should be reasonably stable with temperature.
Regards, Dan.
Old 15th March 2014, 05:28 PM   #33
Elvee is offline Elvee  Belgium
Elvee's Avatar
Here you are, but thermal stability is not exactly a priority if there are dynamic instablities
No
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 16th March 2014, 12:13 AM   #34
megajocke is offline megajocke  Sweden
megajocke's Avatar
ilimezn, the question is how to get it thermally stable. the circuit works in simulation as well as in real world experiment. the only problem with it is the drift.
is there anybody who care for the 431 behavior when its working condition is out of the spec?
In your circuit you are just using the base-collector junction of one of the transistors inside the TL431 (as shown in the attachment) in series between your NPN transistor and the feedback divider.
If you want the TL431 to work in the way it is intended to, for starters the feedback polarity is wrong in your circuit even if you were to provide the TL431 with cathode current.
Old 16th March 2014, 12:24 AM   #35
Regards, Dan.
hi Dan, i meant voltage souce formed by a current source and a load. thanks for your suggestion.
Old 19th January 2015, 01:40 PM   #36
shri9891 is offline shri9891  India
shri9891's Avatar
Hi friends,
I need to build a ±20v supply using two tl041 and two NPN & PNP MOSFET (IRF 540/9540) could any of you post a schematic for that I have been trying hard for this one but no luck....
The input is ±35vDC
TL431 High Voltage Regulator - How to get it thermally stable?Hide this!Advertise here!
Tl431, MOSFET shunt voltage regulator jetbat Power Supplies 5 14th March 2014 03:19 PM
High Voltage Regulator mod_evil Power Supplies 36 28th October 2011 12:48 PM
High voltage, high current super regulator, possible group buy peranders Group Buys 54 2nd June 2009 09:43 AM
CFP diamond buffer output stage with vertical FETs, thermally stable? Russ White Solid State 5 1st January 2008 04:16 AM
High voltage regulator sparkle Tubes / Valves 45 29th August 2004 05:52 AM
